http://pcpartpicker.com/list/XwYqkT
This is basically random as you added no preferences or budget.
 | CPU: AMD FX 8350 + H100i | GPU: AMD R9 290X + NZXT Kraken | RAM: HyperX Beast 2033 16GB | PSU: EVGA G2 | MOBO: ASRock 970M |
| CASE: Corsair Carbide 88R |STORAGE: 1x WD Black | KEYBOARD: Corsair K70 | MOUSE: R.A.T 9 |
SOMETIMES LOSING THE BATTLE, MEANS YOU CAN WIN THE WAR
https://linustechtips.com/topic/618463-recommend-for-build/#findComment-7984167
Is there a specific budget, color you had in mind, and what size do you want your pc?
Mini ITX and Micro ATX are smaller PC's. ATX is a slightly bigger pc. EATX is a VERY large PC.
Any plans you have with the pc? Like gaming, netflix, video editing. It all helps so someone can help you find the best parts for you.
https://linustechtips.com/topic/618463-recommend-for-build/#findComment-7984168
I'd go for at least 700 Watts for the PSU, figure 400 W between the 480s + 200 for the rest of the system, especially if there is overclocking involved
https://linustechtips.com/topic/618463-recommend-for-build/#findComment-7984181
550 is more than enough, and if he wants help selecting other parts, I doubt he will be overclocking the system.
https://linustechtips.com/topic/618463-recommend-for-build/#findComment-7984187
If he is doing two GPUs then ITX wont work as those only come with one 16x slot.... Best place to start is ATX, maybe some of the better MATX might have 2 slots for GPUs, but it will be tight, and those hair dryers need room to breath.
And yes we need more information, Use of computer, Parts you already have, Budget, Color preference, brand favoritism, experience with computers, do you plan on OC, Do you like water coolers, Where will you put your computer? Very important, It is hard to help you warm your toes if your tower is on top of the desk.
https://linustechtips.com/topic/618463-recommend-for-build/#findComment-7984251
1 minute ago, ravy said:
do i need anything else to build this pc ? sorry noob in the house
Not really, but I wouldn't actually go with this build, get someone to make one more suited to your purposes, this was just a random throw together of parts as you didn't specify anything.
https://linustechtips.com/topic/618463-recommend-for-build/#findComment-7984320
I mean that
Is this not good enough for gaming and studying ...
https://linustechtips.com/topic/618463-recommend-for-build/#findComment-7984346
2 minutes ago, ravy said:
I mean that
Well yeah, but you can probably get something better suited for you.
https://linustechtips.com/topic/618463-recommend-for-build/#findComment-7984367
Well, My build is http://pcpartpicker.com/list/D2ZHvK and cost about $1400.  So if you add $100 for the difference in price in GPU, the extra money can get you a Samsung 850 EVO, and what every else you need. It is a good build for me. Tweak as needed.
Actually..... Pick your own case, because the Rad and the case don't line up perfectly... case opening for rad is .4 inches too wide and makes it sit at an angle. Try the Phantek Enthoo Pro case. Cheaper and just as nice.
https://linustechtips.com/topic/618463-recommend-for-build/#findComment-7984502
but if i have 2 gpu wouldnt that last me longer than 1 gpu?
https://linustechtips.com/topic/618463-recommend-for-build/#findComment-7984515
Most games don't really support crossfire so it would be better to just get a single card like the GTX 1070, 1080, or wait for the RX 490/X
Rig Specs:
Ryzen 7 1700 3.9ghz @1.33125v Cinebench Scores Best:1750cb Average: 1735cb
Asrock X370 SLI/AC  SOLD
Evga GTX 560 Ti 1gb    Just got a EVGA GTX 780 HydroCopper
G.Skill Ripjaws V 2x8gb 2400mhz oc’d to 2666mhz (bought when ram was still cheap :()
Corsair RM850
Enthoo Pro M Acrylic Changing to a Inwin 301 soon
Custom CPU Loop (watercooling is boring to me right now so I want to go back to air cooling and do like one more WC Loop in a Inwin 301)
Intel 256gb SSD
Kingston 240gb SSD
HyperX 90gb SSD
Not So Shitbox v3 Specs:
I7 2600k oc'd to 4.7 @ 1.4ish (will do more when I get a better cooler)
MSI P67-GD55  Sold to fund my gpu
Gigabyte Windforce HD 6950
Team Elite Plus 8gb DDR3 (1 stick) @ 1600mhz
Thermaltake Toughpower 750 watt
Cooler Master T4
Enthoo Luxe
Kingston 120gb SSD
WD Black 1tb HDD
Laptop:
Asus GL552VW-DH71
i7 6700HQ
2x8gb DDR4
1tb hard drive
GTX 960m
15in IPS 1080p display
https://linustechtips.com/topic/618463-recommend-for-build/#findComment-7984556
Longer in terms of relevance, Yes.
I'm just showing you what i have now, you want two GPUs, That MOBO can do two GPUs and has a space between them to let air flow.
The price is what you want to look at. They always say, It is better to get one more expensive card and upgrade later if you want, than to get two lower cards, and have to replace both when you want to upgrade.
Two 970s vs a 980TI, get the 980TI, because for the same price, you can get another later instead of buying two later to get something better. Two 480s will do good, but what do you plan to do in the future.
https://linustechtips.com/topic/618463-recommend-for-build/#findComment-7984558
