So, I just got my PCIe wireless card (the Gigabyte GC-WB867D-I, to be exact) in the mail and got it installed. It's all up and running smoothly. However, the antenna is kind of unsightly. My NZXT S340 is this clean black box and then at the top is this black piece of plastic just jutting up. So, I'm just curious: if I were to leave the antenna inside the case (by routing the cords from the outside in), how much of a signal degredation am I looking at? Would it negligible? Noticeable? I'll probably end up leaving it on top but I was just wondering. Thanks.
https://linustechtips.com/topic/617963-quick-question-wrt-wireless-antenna/
there is only one way to find out. bench it with speedtest.net
CPUFX 8320, Motherboard ASUS M5A78L-M/USB3 Socket AM3+ AMD, RAM g.skill ripjaws x series (2x8gb), GPUstrix gtx 970, Storage 500gb + 500gb + 250 ssd, PSU EVGA 600w B 80 PLUS BRONZE, Display(s) ASUS VG248QE 24"+ Hisense 24" + Vizio 24", Cooling Cooler Master Hyper 212 EVO, PC Part Picker  http://pcpartpicker.com/p/LFxQ23
Maybe route it sticking down underneath the table?
or on a monitor?
Woo!
I certainly could, but it was just a thought that crossed my mind.
Regardless, I did the test. First, I ran both fast.com and speedtest.net, with speedtest getting two tests of it's own: one to a server local to Hawaii (where I live) and one in San Francisco. Then, I did the same tests inside the case. Then I did each again to see if speeds were repeatable.
Outside Test #1:
Fast.com: 41Mbps
Speedtest to Hawaii: 71Mbps down, 23 Mbps up
Speedtest to San Francisco: 42Mbps down, 21Mbps up
Outside Test #2:
Fast.com: 43Mbps
Speedtest to Hawaii: 72Mbps down, 24Mbps up
Speedtest to San Francisco: 51Mbps down, 21Mbps up
Inside Test #1:
Fast.com: 34Mbps
Speedtest to Hawaii: 62Mbps down, 23Mbps up
Speedtest to San Francisco: 36Mbps down, 19Mbps up
Inside Test #2:
Fast.com: 34Mbps
Speedtest to Hawaii: 64Mbps down, 23Mbps up
Speedtest to San Francisco: 42Mbps down, 20Mbps up
I think it's pretty safe to say there's some signal degredation there. Something in the range of 15-25% decrease in speeds.
open cmd.exe and type in
ping 192.168.0.1 -t
or whatever your router's local IP is. the -t attribute will make it continue pinging until you close the window or hit CTRL+C. It'll keep going even if you unplug the antenna making it lose the connection altogether. With that running, you can then test out different scenarios easily. My reasoning is, you'll want to rule out as many unrelated variables such as the speedtest servers or your ISP and even your modem(side of the router). You'll see worse connection as bigger ping or the very least as jitter (ping going up and down rapidly) Ping will be more affected by interference than the download speed.
I'm guessing the case will hinder the connection. One reason they make computer cases out of metal is that it's supposed to contain electromagnetic radiation.
At the beginning I assumed that case would hinder connection. I just felt like testing it out because why not. However, I don't really feel like testing it anymore. I found a spot on the outside of the case to stick the antenna and it looks pretty okay. Not too noticeable from the viewing angle the case will most bee looking at from. Thanks for the tip though.
