Pci-e riser (not for mining!)
Go to solution Solved by PokeCatz,
I would get the second one.
i have some overheating issues with my 3 way setup of gtx 770 ,i started a project of modifying a power mac g5 case i thinking of putting 9 expansion slots so i can 3 way sli with a slot in between i already bought a asus 3 way sli bridge flexible off ebay but know i need some pci-e riser i have my eye on these two \/ both the size is more than enough for my plans which  one should i pick , or recommend one yourself
http://www.ebay.com/itm/SINTECH-PCI-e-express-16X-Riser-Extend-Card-15cm-high-speed-Foiled-Cable/321571814072?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20140602152332%26meid%3D2c8404c8aa4e4934b81240c061270377%26pid%3D100011%26rk%3D3%26rkt%3D10%26sd%3D321362874331)
(http://www.ebay.com/itm/Sintech-PCI-e-express-16X-Riser-Extender-Card-5cm-high-speed-Flexible-Cable/221770562888?_trksid=p2047675.c100009.m1982&_trkparms=aid%3D777000%26algo%3DABA.MBE%26ao%3D1%26asc%3D20131227121020%26meid%3Ddfd5b4f15d2b4ab6a21943bea88fc7c7%26pid%3D100009%26rk%3D1%26rkt%3D1%26sd%3D321571814072)
https://linustechtips.com/topic/617362-pci-e-riser-not-for-mining/
1 minute ago, Trevor87 said:
You want the one with the power lead.
Why where would the power lead go to?
CPU: Intel Core i7 3770 @ 3.91 GHz RAM: G.Skill 4x4GB 2133Mhz DDR3 GPU: AMD HD 7970 3GB SSD: Samsung 840 Evo 500GB PSU: Corsair HX620W  Motherboard: Gigabyte Z68X-UD3H-B3 Case: Phanteks P400 Tempered Glass (Black) Monitor: Dell P2412H, Dell 2012H Keyboard: Razer BlackWidow Ultimate Classic Mouse: Logitech G203 Prodigy HDD: WD Black 3TB
7 minutes ago, W-L said:
So is the second one he suggested.
It would go in to your power supply lead.
So a little bit of extra power on the 16x slot. Who cares. Most cards are powered of 6 pin and 8 pin now.
