Hi all, First i wanna begin by saying this forum is amazing.
Now to my problem-(ish)
I wanna build a PC but im on a tight budget. I want to get the PC as fast as i can and im waiting to upgrade later because i do need a PC.
http://pcpartpicker.com/list/rZfpbj
I wanna know if the PC is good enough for now, e.g.(if the ram speeds are good enough).
That is my list, im using an APU for now and planning to get a video card later.
Now i know the budget is low for now, and i know everyone will cringe.
Thank You
https://linustechtips.com/topic/616660-need-help/
I'd swap the 2x4GB ram for a 1x8GB so you can upgrade in the future! Apart from that looks good, 80+ power supply is good to get at any price point and corsairs spec line if not to the taste of everyone are well laid out and constructed to a decent quality. Good Luck!
https://linustechtips.com/topic/616660-need-help/#findComment-7962580
Ah Sweet!! I was actually expecting to get a lot of criticism for having a low budget, lol. Thanks Man.
https://linustechtips.com/topic/616660-need-help/#findComment-7962586
thats a bad idea actually, the igpu does prefer dual channel memory over single chanel you'll lose performance
Main PC:| CPU: Ryzen 5 2600 @ 4.1, MOBO: Asus B350 PRIME , RAM: LPX Vengance 2400 16gb kit, GPU: 980Ti Poseidon Platinum 6gb
                PSU: SilverStone Strider Gold Evolution 1200w , CASE: HAF 932  HDDs:240gb EX900 HP NVME 6TB (2x3 Seagate Barracuda)
                COOLING: ThermalTake Contac Silent 12
Laptop:MSI GL62 7RD  CPU: Core i5 7300HQ, RAM: 16GB 2400mhz, :GPU GTX 1050 2GB: HDDs: 256gb adata NVME + 1TB HDD
love all brands, will go for whats cheaper for my needs
https://linustechtips.com/topic/616660-need-help/#findComment-7962594
No one should be critical of budget as its something that can't be changed (especially if you need a pc for a deadline / schoolwork where saving isn't an option). Also with an APU you will be able to do some light gaming until you get a GPU. Personally I prefer Intel however for the budget AMD is the way to go.
https://linustechtips.com/topic/616660-need-help/#findComment-7962596
http://pcpartpicker.com/list/x7Bbjc
This was a INTEL based build i originally wanted, but i would sacrifice a GPU and i would have to wait a longer time to get one cause i was looking at a 300$ GPU to pair with it but that would take some time and int he time when i don't have the GPU i wouldn't be able to run barely any games.
https://linustechtips.com/topic/616660-need-help/#findComment-7962603
ahh, you'd be surprised of the iGPU performance form Intel, on my i5 i could run Arma 3 at 30FPS. Not 60FPS but still playable until i got my 760.
https://linustechtips.com/topic/616660-need-help/#findComment-7962604
Hmm, i really wouldve liked an intel chip, but my budget just cant make it. I would have to cheap out in the motherboard, ram and case. which i dont want because my plan is this. Build with the APU--->Buy a GPU-->swap to intel. (mobo and CPU)
As much as im tempted to get the INTEL build, im not sure if i could get the money before summer ends.
https://linustechtips.com/topic/616660-need-help/#findComment-7962607
How about this? You can upgrade the CPU and add in a GPU later.
CPU: Intel Pentium G4400 3.3GHz Dual-Core Processor  ($58.99 @ SuperBiiz)
Motherboard: Gigabyte GA-H110M-A Micro ATX LGA1151 Motherboard  ($49.99 @ Amazon)
Memory: Kingston FURY 8GB (1 x 8GB) DDR4-2133 Memory  ($32.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($47.49 @ OutletPC)
Case: Fractal Design Core 1100 MicroATX Mini Tower Case  ($43.99 @ SuperBiiz)
Power Supply: XFX TS 550W 80+ Bronze Certified ATX Power Supply  ($62.99 @ SuperBiiz)
Total: $296.44
Generated by PCPartPicker 2016-06-26 03:37 EDT-0400
Edited by Shahnewaz
Quote
The problem is that this is an nVidia product and scoring any nVidia product a "zero" is also highly predictive of the number of nVidia products the reviewer will receive for review in the future.
On 2015-01-28 at 5:24 PM, Victorious Secret said:
Only yours, you don't shitpost on the same level that we can, mainly because this thread is finally dead and should be locked.
On 2016-06-07 at 11:25 PM, patrickjp93 said:
I wasn't wrong. It's extremely rare that I am. I provided sources as well. Different devs can disagree. Further, we now have confirmed discrepancy from Twitter about he use of the pre-release 1080 driver in AMD's demo despite the release 1080 driver having been out a week prior.
On 2016-09-10 at 4:32 PM, Hikaru12 said:
You apparently haven't seen his responses to questions on YouTube. He is very condescending and aggressive in his comments with which there is little justification. He acts totally different in his videos. I don't necessarily care for this content style and there is nothing really unique about him or his channel. His endless dick jokes and toilet humor are annoying as well.
https://linustechtips.com/topic/616660-need-help/#findComment-7962608
Video Card: Sapphire Radeon R9 380 4GB NITRO Dual-X OC Video Card  ($184.99 @ Newegg)
Total: $481.43
Generated by PCPartPicker 2016-06-26 03:36 EDT-0400
Woah,  thanks. but i would like to be able to play games and use software for AutoCAD,without the GPU(they are a bit pricey). I understand that i would need to sacrifice some power for that. That is why i opted with amd
https://linustechtips.com/topic/616660-need-help/#findComment-7962617
Total: $481.43
https://linustechtips.com/topic/616660-need-help/#findComment-7962623
I edited my post. Didn't mean to put that GPU in the list.
Depending on the game and graphics settings, you should be able to run a few; and AutoCAD doesn't look like it's heavily threaded. So technically, this setup should serve this "emergency" situation.
The reason I'm insisting you stick to a Skylake platform is to reduce the cost of future upgrades. You'll save on RAM, motherboard and a few other components if you pick them right, ie. the PSU, Case and the HDD. All of these parts can be re-used when you will be upgrading the CPU and adding in a GPU.
A CPU upgrade from your list will require replacement of almost everything. The PSU would also be a limiting factor too. :|
Quote
https://linustechtips.com/topic/616660-need-help/#findComment-7962655
On 6/26/2016 at 1:06 AM, Shahnewaz said:
I edited my post. Didn't mean to put that GPU in the list. :|
http://pcpartpicker.com/list/D7w3Fd
This was a build i was looking at for a while, i'm currently 50/50 with either this or the AMD
https://linustechtips.com/topic/616660-need-help/#findComment-7962662
This will further limit your upgrade options. Haswell CPUs will soon be no longer available, and then you'll have to buy used if you want to upgrade to a Haswell i5 or i7. Otherwise, you will have to replace your motherboard and RAM as well for a Skylake upgrade.
It all depends on how much upgradeability is important to you. If you are 100% sure you will upgrade your system in the future, then go for the latest (Intel) platform, even if you have to pick a Pentium. If you don't mind spending a considerable amount in future upgrades, then go AMD. You'll get considerably more performance now, but this is the more costlier approach.
Quote
https://linustechtips.com/topic/616660-need-help/#findComment-7964535
