Hello all!
I recently completed my first custom loop. but i think my cpu temp under load is not good. Here are my specs
I7 4790k(at stock)
GTX 980ti reference
1 ek 120mm slim rad
1 ek 240mm slim ra
EK-XRES 140 Revo D5 PWM (incl. pump)
ek supremacy evo and Titan X water block
Ambient temp around 21 C
Res/pump > GPU > 120rad > CPU > 240rad > Res
NZXT S340
When i running AIDA 64 stress test, the cores hit above 70 C,i have removed and reinstalled my CPU water block, it did not work, temps at idle are ok, around 30~ 35 C, is it normal?
but my GPU temps are fine, below 50C under full load.
Any Suggestions or advice are greatly appreciated!
https://linustechtips.com/topic/616435-custom-loop-cpu-temp-problem/
What are your temps then? You didn't give us any, we can't tell just by your CPU.
EDIT:
Ok, I see you edited the first post. The temps seem fine for a normal setup, but they should probably be a little lower in a custom loop. We need to wait for some custom-loop experts to see, but I suggest to post a picture of your build, if that's not a problem.
In AIDA 64, do you stress just CPU or also FPU and cache?
If you stress test just CPU, temps should be lower.
I was using single 240mm rad for i7 4790 and GTX 1070. Temps went above 80°C, so I decided to upgrade with additional 360mm rad.
Had same case as you, and fitting everything inside was a nightmare. So I bought Define S, to fit 360mm + 240mm rad.
Waiting for 360mm rad + GPU to come from RMA to test temperatures.
When you grab those tubes ... does it feel warm?
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
