2 minutes ago, kingpenguin said:
I have the Intel Pentium G3258 and a GTX 750 running on a cx430 PSU works just fine now I want to upgrade my cpu which will increase my power intake from my cpu by 42 watts so what im woundering is if I can run the new cpu and same gpu on the same psu the cx 430??
The CX430 should be fine
Wouldn't be enough for a midrange+ system (less about its wattage and more about PSU quality) but it should be fine
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/616077-enough-power/#findComment-7957104
Ok so me running on the 430 for bout a week or 2 should be fine before I get a 750 or so.
https://linustechtips.com/topic/616077-enough-power/#findComment-7957108
You can run a high-end system on 550W. Here's a couple recommendations at different price points, choose the one you're willing to spend the money for (as the cost increases, nice to have things like modular cables and silent fan operation start showing up and getting better)
http://pcpartpicker.com/product/3hkwrH/corsair-power-supply-cp9020102na - $54.99
http://pcpartpicker.com/product/kz7CmG/evga-power-supply-210gq0650 - $69.99
http://pcpartpicker.com/product/qYTrxr/evga-power-supply-220g20550y1 - $74.99
http://pcpartpicker.com/product/9G7wrH/xfx-power-supply-p1650bbefx - $94.99
Computer Specs:
https://linustechtips.com/topic/616077-enough-power/#findComment-7957126
Those two parts are totally fine on a CX430. Any current CPU would be fine on it with a 750ti.
https://linustechtips.com/topic/616077-enough-power/#findComment-7957139
