Go into the Audio Center (you need to install the asus xonar program)
Change analog out to headphone, click Dolby Headphone + 7.1 virtual speaker shifter.
Its virtual surround sound, just so you know.
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
https://linustechtips.com/topic/61569-surround-sound-in-games/#findComment-839433
Yes that will work but it won;t be any more accurate than the sound cards virtual surround.
You can't just magically make surround accurate with a pair of headphones...its all approximation as they only have two drivers.....7.1 headsets (with multiple drivers are better, but...meh, don't like them, they are also heavy...)
I find it better to use normal stereo to pinpoint where a sound is coming from, find it better than virtual surround and you don't have to distort the sound to a silly degree.
https://linustechtips.com/topic/61569-surround-sound-in-games/#findComment-839565
Did you use Logitech G35 for example? I used it few times and by the time i returned it to shop where they came from, i'm looking for such great positioning and surround sound as they've had. I did' not like music on this headset but i regret that i returned them.
https://linustechtips.com/topic/61569-surround-sound-in-games/#findComment-839589
The Logitech G35 isn't a 7.1 headset, its a 7.1 virtual surround headset, it only has two drivers, and its accuracy is questionable.
And no I've never used it, as I prefer normal 2.1 stereo.
If you want true surround sound in a headset then you need to get something like the Roccat Kave, which has multiple drivers in each ear cup (basically a true surround system condensed into a headset.  But there are draw backs, the drivers are small, so sound quality is not exactly brilliant and they are heavy....
https://linustechtips.com/topic/61569-surround-sound-in-games/#findComment-839609
I've never bought into this hype of 5.1/7.1 surround gaming using headsets, separation cannot be good no matter how many drivers there are in the headset. They are enclose in such a small space, makes audio separation..........negligible at best. I tried it once a ways back, using my X-Fi XM + Razer HP-1 (among the first headsets with multiple drivers), bass was lacking, separation sucked the big one.....the overall experience was just so underwhelming to say the least. I'd used 3 minijacks to connect the headset to my soundcard for 6 channels.....
 Main Rig: AMD AM4 R7 5700X3D (8C/16T) + TR Phantom Spirit 120 EVO | Gigabyte X570 Aorus Xtreme | 2x 16GB Kingston Fury Beast DDR4 3600 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Crucial P310 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Logitech G915 + G303 Shroud Ed + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 24H2
2nd Rig: AMD AM4 R9 5900X (12C/24T) + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS) | 2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Logitech G613 + G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 24H2
HTPC: AMD R7 6800H | 32GB DDR5 4800MHz | AMD 680M iGPU | 2TB SSD (2 Partitions 400GB + 1.4TB)) + 1TB SSD | Logitech G613 + G304 | Win11 Pro  24H2
Laptop: Lenovo Legion 5 Pro 16ACH6H - AMD 5800H | 32GB DDR4 3200MHz | 680M iGPU | 1TB Kingston NV1 NVMe M.2 (OS) | 4TB Lexar NM790 SSD | Win11 Pro
https://linustechtips.com/topic/61569-surround-sound-in-games/#findComment-841410
But I'm talking about virtual surround not discrete surround. Maybe I just have bad headphones for this. Coz most of reviews of Xonar DX are praising its virtual surround sound abilities via Dolby Headphones. Maybe Razer Carcharias are just bad for surround sound experience? Maybe should i buy Steelseries Siberia V2?
https://linustechtips.com/topic/61569-surround-sound-in-games/#findComment-843263
If you set your soundcard to simulate a 7.1 surround sound setup and also tell the game to produce surround audio it should work very well. I have a DGX and just love the way surround sounds, going back to normal stereo feels weird for a few minutes, because I'm not used to hearing voices in my head anymore xD
In the software you can also make the virtual 7.1 surround sound system rotate around your head, you should try it it really shows how well it works ^^
AMD FX8320 @3.5ghz |  Gigabyte 990FXA-UD3  |  Corsair Vengeance 8gb 1600mhz  |  Hyper 412s  |  Gigabyte windforceR9 290  |  BeQuiet! 630w  |  Asus Xonar DGX  |  CoolerMast HAF 912+  |  Samsung 840 120gb
2 WD red 1tb RAID0  |  WD green 2tb(external, backup)  |  Asus VG278He  |  LG Flatron E2240  |  CMstorm Quickfire TK MXbrown  |  Sharkoon Fireglider  |  Audio Technica ATH700X
#KILLEDMYWIFE
https://linustechtips.com/topic/61569-surround-sound-in-games/#findComment-843729
Finally someone who used sound card and can really help. I use settings like that 8 channels Dolby Headphones ON In game headphones set and in win7 set to 8 channels, but i think my headset doesn't work well with surround sound. I need to buy steelseries siberia v2 i think. Mine is semi open.
https://linustechtips.com/topic/61569-surround-sound-in-games/#findComment-843900
Which do you have? I have razer orcas and they are also semi-open and they work great with surround.
Set the 7.1 shifter up like this:
http://prntscr.com/1uup0d
then listen to some music, close your eyes and try to localize where the virtual speakers are. you should be able to hear them traveling around you.
#KILLEDMYWIFE
https://linustechtips.com/topic/61569-surround-sound-in-games/#findComment-844604
