Nope. Unless you plan on ONLY using it with a Samsung Galaxy S6, S6 Edge, S7, S7 Edge, or Note 5. That's it. That's all it works for (officially, at least, direct from Samsung). I'd recommend saving for a VR system for your computer, or going the Google Cardboard route and fixing up a way for it to sit like a cap would, without you having to hold it at all times during use.
Recommendation comes from first hand experience with Oculus Rift DK2, Gear VR, and Google Cardboard. Yes, the Gear VR is flipping neat and all, but it has a very limited application.
FX-8350 | GA-990FXA-UD3 | G.SKILL 2x8GB 1600MHz | 1TB WD RE4 | CM Hyper 212 EVO | MSI R9 290x Lightning | Corsair AX860i | Silverstone FT05B-W
Pentium G3258 | MSI Z97 PC Mate | G.SKILL 4x4GB 1066MHz | 500GB Samsung 2.5" | Stock cooler | Pending GPU | EVGA 500B | Antec DF-35
GoPro Hero 3 Silver | Netgear R7000 Nighthawk with DD-WRT | HP Officejet Pro 8610 | Canon iP110 | AudioTechnica ATR2500 USB
Downdraft cooler for mITX board (new build) | Desk mount mic stand | Pop filter | Anti-vibration mount for microphone | mITX case | 3rd monitor (matching existing 23.1" | Intel Core i7-4790K (for mITX build)
https://linustechtips.com/topic/615643-gear-vr-worth-it/#findComment-7952502
