PC-Build Components
Solved by Herman Mcpootis,
3 hours ago, CurryKeks said:Okay my new Plan:
The Seagate 2TB SSHD (I didn't find a name) (90€)
16GB DDR4 HyperX Fury
An i5 6500
The ASUS H110M-K
Still the Define R5 Case (I really like it)
A random LG DVD-Drive
I'm still deciding on the graphics card, because the 1070 is overkill but the 970 isn't quite good enough and the 980 (Ti) isn't woth it's price.
Your compromise will be the rx 480, seems to have the performance of a gtx 980 while being only $200usd.
