Another Power Draw Question
Solved by Narnash,
Wich GTX 1080 you use that you get a max. of 390W ?(btw you linked the CPU twice) the biggest 1080 should have 2 x 8pin + PCIe .... so 375W as a absolute maximum (wich need to be BIOS modified to use it I guess)
And for the GTX 680 the same ... in the linked review you can see the full load setup power draw .... by the conections of the GTX 680 you have it can't draw more than 300W
I say that you 850W should be fine for all. But I must say that is's probably not woth it to use the GTX 680, kinda pointless I would sell it.
