4 minutes ago, prs2492 said:
I want to know what coolant material is used for cooling in the liquid cpu coolers that come pre-installed with coolant, like for example, in corsair hydro series h60 cooler?
Most likely distilled water and a biocide to prevent algae and bacterial growth.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/615232-liquid-coolant/#findComment-7946699
Pretty much the same coolant that a car uses.
Current PC: "For Now Because I Have A Habit"
CPU: Intel Core I7 6700K @4.5Ghz
Motherboard: Asrock Z170 Extreme4
RAM: 16GB G.skill TridentZ 3200Mhz DDR4
CPU Cooler: Thermaltake Water 3.0 360 Riing RGB Edition
Graphics Card: Nvidia Geforce GTX 1080Ti Founders Edition MSI
Case: Limited Edition Thermaltake View 31 Riing RGB
Power Supply: CoolerMaster V750 Fully Modular
SSD: Kingston HyperX Savage 240GB
HDD: 3TB Toshiba 7200RPM
Peripherals:
Monitor: AOC U2868PQU 4K 28" 60HZ
Keyboard: G.Skill Ripjaws KM780 RGB Cherry MX Red
Mouse: Razer Deathadder Elite
Mouse Pad: Razer Goliathus Speed Extended
Speakers: Creative SBS A250
Headphones: Razer Kraken Pro 7.1
https://linustechtips.com/topic/615232-liquid-coolant/#findComment-7946702
depends on what your thermal goals are. most using a system do have a budget and liquid cooling eats into that budget.
do you have to liquid cool? no. should you liquid cool? depends on your budget, achievements, and your overall build appeal.
https://linustechtips.com/topic/615232-liquid-coolant/#findComment-7949885
Watercooling is normally something you do when you dont have much of a budget in mind. Normally you'd be better off saving the money and putting it towards better parts. But, if you already have top end parts with extra money then water cooling is a good way to achieve great overclocks.
CPU: I5 4590 Motherboard: ASROCK H97 Pro4 Ram: XPG 16gb v2.0 4x4 kit  GPU: Gigabyte GTX 970 PSU: EVGA 550w Supernova G2 Storage: 128 gb Sandisk SSD + 525gb Mx300 SSD Cooling: Be Quiet! Shadow Rock LP Case: Zalman T2 Sound: Logitech Z506 5.1 Mouse: Razer Deathadder Chroma Keyboard: DBPower LED
https://linustechtips.com/topic/615232-liquid-coolant/#findComment-7952039
Thanks for your promot replies, really helpful
So, basically i can achieve higher overclocks with decent temperature in liquid cooling, rather than the air cooling, and i can go for it if i have the money to spend considering other parts. So, i'll go for it.
Whats the life of these aio liquid coolers, and does it last longer than the air coolers?
https://linustechtips.com/topic/615232-liquid-coolant/#findComment-7952644
Usually AIO last at least 5-7 years as per their warranty, but also add an extra point of failure to air cooler since it uses a pump, that is what usually goes first on those units where fans on AIO and air coolers can easily just be replaced.
https://linustechtips.com/topic/615232-liquid-coolant/#findComment-7958167
