Asus Z170 Hero Alpha and fan voltage?
brandonb21
i bought two 140mm noctua nf-a14 fans for my corsair h110i GT and im wondering my CPU_OPT fan header using a pwm splitter will be safe as i cant find anything about fan header voltage in the manual? i think one fan uses 12 volts so thats 24 volts in total. i just didnt want to blow something up
you'll be fine, not even a problem unless you try to plug a delta fan in or daisy chain like 8 normal fans
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
Each header on mobo will supply max 12V. Its Amps you need to look at. Most headers will supply 1A of currency and you can fit 3-4 fans to single header, all of them running max 12V.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
is it 1amp in total for all headers  or 1amp per header?
Per header. Same as with max delivered volts.
:D thanks
