*I have included handy dandy hyperlinks, which are the color green, to illustrate specific things through images or gifs*
The Problem
My new 3TB HDD will not initialize when I so kindly ask it to; instead, the virtual disk manager informs me that "the request could not be performed because of an I/O device error."
More Information
  • Specs of PC
  • Event Viewer's more informative version of the error
  • Information about the disk according to diskpart
    • Well, that used to be the information until I realized that the HDD was read-only yet again. I attempted to fix it by typing "attributes disk clear readonly," and now the disk will not show up in diskpart (there's only 3 disks there now. None of 3TB either). I had converted it from readonly several times because that fixed my problem for many people. It would always changed back, and I never had the problem of disappearance until just now as I'm writing this. The HDD also still shows up on Speccy and in Disk Management if you were wondering.
  • The other HDD I'm currently using is a Seagate. Shouldn't be a problem with the drivers I don't believe.
What I've Attempted
  • I have changed both the power and SATA cables multiple times, and I'm 100% certain that's not the problem.
  • I've tried initializing as both types (even though you're supposed to use GPT for 2TB+ HDDs).
  • I've tried cleaning it through diskpart.exe.
  • I tried running SeaTools (Seagate's diagnostic utility); however, it did not register the drive. I think that's because it's not initialized.
Any ideas that you can give I'll be very thankful for! Also, if there's any information I can add, let me know. Thank you so much for reading this. :D
https://linustechtips.com/topic/614237-having-trouble-initializing-a-hard-drive/
You got a dead first gen segate 3tb The 3000m0001 ones. I got a stack of bad ones(4 of 5) and try to return it. Since that the drive shoes up as 3.8 gb tells me its probably bad.
Thanks for that information. I bought it through Amazon. I just pray they will let me return it.
