I'm upgrading from a GT 720 to a GTX 950.
I got a new power supply, 500W, and for some reason, when I start the computer up, the GPU won't! D:
I press the power button, then it goes BEEP, BEEP, which it's supposed to do because the GPU's fan won't move, and then the CPU and back(exhaust?) fans work, but not the GPU, nor its fan. I tried switching from 130 to 240V, which made it even worse, as the computer would straight-up crash, restart, and then crash again, over and over.
What am I doing wrong!? Please help meh! :(
Thanks! :P
https://linustechtips.com/topic/614084-950-not-starting-up/
Thanks! :P
Which GTX 950 do you have? because a lot of them keep there fans off till they reach a certain temperature.
Sergeant, United States Marine Corps
Network Administrator, Comptia A+, Security+, Cisco Certified Networking Associate
From a G3258 to dual Xeon E5-2670's
https://linustechtips.com/topic/614084-950-not-starting-up/#findComment-7934412
Does it require an external an external power connection?
Oh, I have the Zotac. Yes, it does have that technology, but it should still at least output a signal! :|
https://linustechtips.com/topic/614084-950-not-starting-up/#findComment-7934423
Yes, a six pin, which I plugged into it.
Remove the GPU, and see if your PC will run off your IGPU.
https://linustechtips.com/topic/614084-950-not-starting-up/#findComment-7934438
11 minutes ago, yb4zombeez said:
WHAT THE FUCK!? All of a sudden, it started to work with the IGPU! :o WHAT THE ACTUAL FUCK!?
Good stuff! What did you do different?
Maybe the GPU was dying, or was dead. Best bet is RWA the GPU and get a new one... :D
ABOUT ME: Hello, I'm a 15-year-old PC enthusiast. I love helping people with their problems and learning about the hardware of a PC.
DREAM JOBS: Computer Technician, I.T Consultant or a Computer Hardware Engineer.
NEXT BUILD: http://nz.pcpartpicker.com/list/rDXLJV (NOT COMPLETED)
BE NICE TO ONE ANOTHER AND HAVE SOME FUN!
https://linustechtips.com/topic/614084-950-not-starting-up/#findComment-7934565
Okay, so it works with the iGPU- that's a step in the right direction. Now uninstall any previous display drivers.
https://linustechtips.com/topic/614084-950-not-starting-up/#findComment-7934568
Drivers. All drivers. I used Chrome Remote Desktop and installed the drivers from there.
https://linustechtips.com/topic/614084-950-not-starting-up/#findComment-7965547
You shouldn't really do that...
Go on to the Nvidea and AMD website and install the drivers there, the latest ones ;)
*Make sure the GPU is out also*
https://linustechtips.com/topic/614084-950-not-starting-up/#findComment-7970415
No, no, no. You misunderstand. Chrome Remote Desktop is an application which allows you to access and control your computer from another device. The reason I had to use it was that the drivers were not installed yet so the GPU was not outputting a signal to the monitor. The drivers were ready to be installed(from Geforce Experience, it's 100% first party, developed by Nvidia and available on their website), so I just clicked the notification that said "Drivers are ready to be installed!", and then it worked. Chrome Remote Desktop saved my ass. xD
https://linustechtips.com/topic/614084-950-not-starting-up/#findComment-7980586
Oh, nice dude. :D
https://linustechtips.com/topic/614084-950-not-starting-up/#findComment-7983895
