Difference between display port 1.2 and 1.3
Any major differences?
I'm looking at the Asus Predator X34 g-sync monitor and using it with a 1070 card. Apparently the new nvidia cards support display port 1.3 and the monitor's port is 1.2. Are there any downfalls to using this monitor or should I look at a newer model that includes display port 1.3?
Thanks
https://linustechtips.com/topic/614063-difference-between-display-port-12-and-13/
I'm looking at the Asus Predator X34 g-sync monitor and using it with a 1070 card. Apparently the new nvidia cards support display port 1.3 and the monitor's port is 1.2. Are there any downfalls to using this monitor or should newer models include display port 1.3?
Thanks
Thanks. I should also mention I'm aiming for 1440p resolution and a 75-100hz refresh rate for gaming.
