My pc rig atm: Intel Core i7-5930K (15MB Cache, up to 3.70 GHz), s2011-3 MSI GTX 980Ti Gaming 6G, 6 GB DDR5, 384-bit, 1228/7100 MHz ASUS X99-DELUXE/U3.1, s2011-3 DDR4 32GB (4x8GB) Corsair Vengeance HDD 3TB WD Black, 3.5", 7200RPM, 64MB Cache, SATA3, SSD 512GB Samsung 850 Pro CORSAIR Hydro Series H110i GT 280mm Extreme Performance Liquid CPU Cooler Corsair 760W, AX760, modular
I will buy 2x VGA Zotac nVidia GeForce GTX 1080 Founders Edition. I wont do overclocking. But my psu will work on 90% of his power. Should i be worried (psu is bought 4 months ago) or buy better psu? http://outervision.com/b/CAhcED
Thanks!
https://linustechtips.com/topic/613596-psu-help/
Thanks!
The AX760 is more than enough for two 1080s.
https://linustechtips.com/topic/613596-psu-help/#findComment-7929102
