I'm planning to reuse my old but decent (I think) motherboard, the manufacturer is HP and the model number is 3370, but I found out that it doesn't have the normal 24 pin connectors for the psu, the psu that I'm using right now is from hp, it consist of 1x 4 pin connector, 2x 6 pins, I don't know what to do. I'm planning to buy CX Series™ CX650M.. and wondering if it's going to be compatible. This is the only hindrance I'm having right now from building my first gaming pc. Thank you in advance.
https://linustechtips.com/topic/613432-motherboard-help/
What socket is that motherboard? It's using proprietary connectors which would require you to either use HP's own PSU or change the connectors on the CXM PSU to what it is on the motherboard :/ (which is a bad idea) so depending on what socket the motherboard is, it may be a better idea to either get a new motherboard with a newer socket or...idk :P
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/613432-motherboard-help/#findComment-7926981
