Right, so this is my first build. Bear in mind that I only started watching LTT's channel after I'd bought half the stuff so I wasn't particularly well informed to start off with :P
The build so far:
Case: NZXT Phantom 410
CPU: i7 4770k (stock clocks for now, does overclock well though)
Mobo: Gigabyte Z87X-D3H
RAM: 16GB / 2x8GB Corsair Vengeance @ 1600mhz
PSU: XFX 850w Pro Black Edition
Monitor: Asus vs239hr 23" LED
Storage:
 - 256GB Plextor PX-256M5P SSD (main/boot drive)
 - 240GB Intel 335 Series SSD (dedicated game drive)
 - 64GB SanDisk SSD (for lulz)
 - 1TB Seagate Barracuda (mass storage)
Keyboard: Ducky Shine 2
Mouse: Cyborg r.a.t 5 and DarkGlider mouse mat
OS: W8. For all its flaws, mostly being my personal lack of desire to co-exist with Metro, it's ffffffast! I'm all booted up and on Firefox at full speed in about 10 seconds.
Optical: LiteOn Blu Ray/DVD reader (cheap as hell, but works a charm)
& finally some generic pci wifi antenna, about 7 years old, from my first PC.
I'm posting this here because I have some more stuff arriving over the next few days, namely a h100i and a 770gtx. I'm hoping to do a picture log of my experience installing them (the h100i mainly). Will update this post when they arrive! I will use an actual camera in the future as well... but in the meantime:
I have bought some more zip ties as well, and I'll be rewiring everything. It isn't overly messy but with some new fans coming as well, I'm going to try and get it perfect. I'm getting a Silverstone AP123 for the bottom grille (intake with dust cover), 2x AP121-BL's for the front/HDD bay (intakes), and another one for the top-rear exhaust. As for the h100i stock fans, I'll decide on a replacement later if need be.
For the inquisitive amongst you, allow me to explain the reasoning for the 770 (which is a Gainward 2GB Phantom, btw):
It's a perfectly capable card, and a good stop-gap until AMD releases their next line. I had my heart dead-set on the 780 classy since the beginning, but simply couldn't justify the cost:performance ratio with all this talk of AMD's new line around the corner. Moreover, I've seen these Phantoms go for near full retail price (the price I paid, anyway) on eBay, so maybe this will go towards an sli setup in the future, or maybe even a r9 290x? To sum up, I'm dying to get back into PC gaming and this is my "on the fence" yet executive decision :P I know I'll be able to recoup at least some of the cost at a later date which can go on something a bit more beastly.
Cheers!
https://linustechtips.com/topic/61340-phantom-410-first-build/
Your rigs looks pretty nice, however I would recommend spending some time on cable management when the other components arrive.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
https://linustechtips.com/topic/61340-phantom-410-first-build/#findComment-835952
Your case has really nice cable management USE IT!!!
| 3570k @ 4.4.ghz | Hyper 212 evo | 8GB (2x4GB) 1600mhz Corsair Vengeance | Gigabyte Z77X UD3H | Corsair CX750M | Corsair 300R | OCZ 240GB SSD | Seagate 1TB 7200rpm HDD | Asus DCUII 7950 @1150mhz core 1600mhz mem
| BenQ XL2411T | Corsair Vengeance K60 | Logitech G700 | steelseries Qck+ | Fiio E10 | Zalman clip on mic | HD 598 | ATH-M50 |
https://linustechtips.com/topic/61340-phantom-410-first-build/#findComment-835957
No argument there, I have an idea of where I'll be routing everything however the XFX cables are SO stiff, they're obviously very high quality but damn near impossible to bend into the position I want it in.
https://linustechtips.com/topic/61340-phantom-410-first-build/#findComment-835992
My 6 pins and 8 pins as well as my 24 pin are too I hate it just try and tidy them before your gpu and cooler get there and you'll end up with a really nice build
https://linustechtips.com/topic/61340-phantom-410-first-build/#findComment-836050
Did you have a problem with the rubber grommets just falling out when you threaded a wire through? I did so I just took them out.... Looks nice :)
Setup: i5 4670k @ 4.2 Ghz, Corsair H100i Cooler, Corsair Vengeance Pro 16GB Ram @ 1600 Mhz, MSI Z87-GD65 Motherboard, Corsair GS700 2013 edition PSU, MSI GTX 770 Lightning, Samsung EVO 120 SSD + 2TB&1TB Seagate Barracudas, BenQ XL2411T Monitor, Sennheiser HD 598 Headphones + AntLion ModMic 4.0
https://linustechtips.com/topic/61340-phantom-410-first-build/#findComment-836064
Yeah, I ended up pushing them back into place after all the cables were in. I toyed with the idea of just taking them off, but ended up deciding the black kinda worked aesthetically. If I'm ever feeling particularly vain one day with 20 something quid to spare, I might look into buying some of those corsair coloured cables :P
https://linustechtips.com/topic/61340-phantom-410-first-build/#findComment-836124
  • 2 weeks later...
Here she is.
post-40963-0-30000300-1381350078_thumb.j
Added a NZXT Sentry Mesh fan controller, works better than I'd hoped. Full range of speed control from the bottom of the slider to the top.
post-40963-0-92104800-1381350107_thumb.j
Installed the h100i. Something of note: I did my research before buying, and heard some users complaining about high temps - apparently due to the back plate not making full contact with the back of the motherboard. I bought some rubber washers beforehand and managed to eradicate this. Yes, the issue was very obvious without the washers in place.
post-40963-0-04107600-1381350223_thumb.j
Finally, I got an LED strip with brightness and on/off controls :). The way I sit at my desk, I don't even see into the PC. It just makes me happy, knowing it's there. Weird?
post-40963-0-24145200-1381350536_thumb.j
"No, the only thing that's [still] weird is your cable management"
OK, OK.  That 4th SSD is a pain, but I like the big HDD bay not being there. I'm going to buy some more flexible cables and hide it in the side panel. I'll also find a way to get rid of those visible SATA power cables!
Cheers!
***edit - how could I forget to mention the GPUlessness? Basically, my order got screwed up and I'm glad. I ended up not getting the 770. I'm going to wait for some proper benchmarks and reviews of the new AMD, if it doesn't live up to expectations, I'll get the 780 classy my heart was always set on.
https://linustechtips.com/topic/61340-phantom-410-first-build/#findComment-875659
looks good so far, but can't you just shove that ssd behind the motherboard tray or in an optical bay. i have my hdd and ssd in an optical bay.
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/61340-phantom-410-first-build/#findComment-875786
