Very strange problem
Go to solution Solved by alexnt,
Finally I found out what was causing the issue!!!
It was the wifi pci card. I removed that evil thing and I can install windows normally!!!
Remove all power sources and hold down the power button for 5-10 seconds and then try. It could be that the on-board graphics have died and wont display graphic intense things. Try getting in to the bios as well and load factory default settings, may be called something else.
Have you tried turning it off and on again?
https://linustechtips.com/topic/613390-very-strange-problem/#findComment-7927677
I believe it is the graphics too. I have already restore defaults.
https://linustechtips.com/topic/613390-very-strange-problem/#findComment-7928188
23 hours ago, ganja7 said:
I try to install windows 7 or 8 on a samsung nc110 netbook from usb and it hangs at these screens:
Even mini xp from hirens, after loading bar force the netbook to restart.
What is going on???
Specs pls.
Is this is a "Genuine" copy of Windows?
Judge a product on its own merits AND the company that made it.
How to setup MSI Afterburner OSD | How to make your AMD Radeon GPU more efficient with Radeon Chill | (Probably) Why LMG Merch shipping to the EU is expensive
Oneplus 6 (Early 2023 to present) | HP Envy 15" x360 R7 5700U (Mid 2021 to present) | Steam Deck (Late 2022 to present)
Mid 2023 AlTech Desktop Refresh - AMD R7 5800X (Mid 2023), XFX Radeon RX 6700XT MBA (Mid 2021), MSI X370 Gaming Pro Carbon (Early 2018), 32GB DDR4-3200 (16GB x2) (Mid 2022
Noctua NH-D15 (Early 2021), Corsair MP510 1.92TB NVMe SSD (Mid 2020), beQuiet Pure Wings 2 140mm x2 & 120mm x1 (Mid 2023),
https://linustechtips.com/topic/613390-very-strange-problem/#findComment-7931214
5 hours ago, AluminiumTech said:
Specs pls.
Cpu atom and ram 1 gb. It has nothing to do as it had win starter by default.
Have already tried with another hdd. Have tried only with usb. Have tried many OS but none can be installed. The same usbs work on another computer.
https://linustechtips.com/topic/613390-very-strange-problem/#findComment-7932877
Windows doesn't run well with 1GB RAM. Make sure you are trying to install a 32 Bit OS since you can't use 64 Bit
https://linustechtips.com/topic/613390-very-strange-problem/#findComment-7933991
Windows 7 starter was preinstalled to the system and it is 32bit. There is no recovery as someone had erased the hdd.
https://linustechtips.com/topic/613390-very-strange-problem/#findComment-7938156
