GTX 980 locked at 405 MHZ
Solved by callum92,
Try this, go to windows power options and click "Change advanced power settings", then scroll down to where it says "PCI Express" then "Link State Power Management" and check what this is set to, it's probably set to off if you have high performance active. Change it to "Maximum power savings" and restart, then go back and change it to "Off" again and restart once more. See if that helps. May just be an issue with that setting.
Featured Topics
em_lab ·
Posted in Power Supplies2 -
Johno Duderino ·
Posted in Networking0 -
2
1
2
Dan1718 ·
Posted in Troubleshooting1 -
1
Zexer2020 ·
Posted in CPUs, Motherboards, and Memory2 -
martixy ·
Posted in Phones and Tablets1
