i mean there is some stuff, but that stuff is not effective
Omega-  I5 6600k | Gigabyte GTX 1060 | Cougar Panzer | DDR4 16GB 3000MHz | MSI Z170 Gaming M5
               EVGA 650 GQ | AOC 60Hz Freesync Panels x2 | AOC 144hz Freesync Panel x1
Epsilon- I7 2700k | Asus GTX 970 | Corsair 780t | DDR3 8GB 1600MHz | EVGA Z68 FTW Mobo
               Corsair 750W G2 | Acer R240HY x2
Upsilon- i7 5500u | 6GB DDR3 | 720p 60Hz panel
https://linustechtips.com/topic/612684-best-audio-enhancer/#findComment-7918796
10 minutes ago, z123killer said:
Is there free software that can enhance the audio outputting from earbuds/headphones?
Equalizer APO
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/612684-best-audio-enhancer/#findComment-7918817
What exactly do you mean? There aren't any piece of software that will magically make your sound better.
There are system wide equalizers that will let you tune the audio to your preference, but whether or not that will "enhance" the audio depends on your own preference.
I can recommend Equlizer APO with the Peace GUI.
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/612684-best-audio-enhancer/#findComment-7918878
Well I want something like an equalizer but it auto adjusts levels based on my sound device to make it sound better
https://linustechtips.com/topic/612684-best-audio-enhancer/#findComment-7918902
Well, "better" is in eye of the beholder, so a program doing the adjusting for you wouldn't really be any good.
Personally, I do also prefere to determin what sounds good for myself and not have a program tell what sounds good.
I would recommend that you give Equalizer APO a shot. In my experience that is the best system wide equalizer, and you can always set up different profiles to correspond with different sound devices.
https://linustechtips.com/topic/612684-best-audio-enhancer/#findComment-7918920
