Put a new build together tonight. Still new at this and need help trouble shooting. Build specs below:
phanteks enthoo luxe case
cpu: Intel i7 6700k
mobo: asus z-170 deluxe
cpu cooler: enermax ets t-40 fit
ram: 16gb corsair vengeance lpx ddr4 3200 Mhz
hd: Samsung evo 850 500GB ssd
Power supply: corsair cx 750m
When I turned on the system for the first time all the factory case fans came on with the exception of the front 200mm fan. I checked all connections and it is hooked up. The pwm fan header is connected to the cpu fan header. Anything I am missing? I also get the following error on my monitor "cpu fan speed error detected" "ensure that the cpu fan is properly installed on the cpu_fan header or adjust/disable the fan speed low limit option in the UEFI bios.
Does this sound like a hardware or software (BIOS) problem?
Thanks in advance.
Below are pictures of the fan hub in the rear of the case along with the error message I get...
https://linustechtips.com/topic/612612-case-fan-not-working/
Did you try plugging the fan directly into a motherboard header or using a Molex to 3-pin fan adapter to verify if it's the fan itself or the fan controller?
https://linustechtips.com/topic/612612-case-fan-not-working/#findComment-7917919
No, I will give that a try, thank you for the suggestion.
https://linustechtips.com/topic/612612-case-fan-not-working/#findComment-7917921
That CPU fan speed error is when whatever fan header you plugged in the CPU fan header is not spinning.
Have you tried plugging it to the Case Fan headers instead?
CPU: Ryzen 2 2700@ 4.0Ghz    Mobo: Gigabyte X470 Gaming 7 Wifi    Cooler: EVGA CLC 240    GPU: GTX1080 FTW DT @ 2113Mhz   PSU: EVGA 750W P2
Case: Fractal Design Meshify C   Displays: 34" LG34UC79G, 24" Dell
https://linustechtips.com/topic/612612-case-fan-not-working/#findComment-7918520
I plugged the cpu fan into the w_pump header. The cpu fans spin. Did I do something wrong by plugging cpu fan into wrong header?
https://linustechtips.com/topic/612612-case-fan-not-working/#findComment-7918653
If nothing is plugged in the CPU_FAN header on the mobo (the one closest to the socket with this label on it), then the system will assume that there is no CPU fan, and it will display that error and will not boot to prevent CPU overheating. It will even display that error if you plug your CPU fan to the CPU_OPT fan header, you have to plug in the main CPU_FAN header.
If you plugged ur CPU fan to the case fan header and want to turn off the warning, you can disable the warning by going in BIOS and find under PC health monitor or something like that, and disable the CPU Fan Fail Warning. After that you wont see it again
https://linustechtips.com/topic/612612-case-fan-not-working/#findComment-7918721
Thank you. I swapped the cpu cooler to the cpu fan header and that allowed me to boot fine.
Also confirmed bad fan on case. Phanteks already shipped out a new one.
Thanks to to everone for the help, much appreciated.
https://linustechtips.com/topic/612612-case-fan-not-working/#findComment-7919362
