So I flashed a newer bios ( all specs in desc ) and going to OC it a bit on the stock cooler.
Can't seem to find any solid source of max temp.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/612307-i3-6100-max-temp/
1 minute ago, DominicNikon said:
keep the cpu under 80C
Ight, just to note to others this is temporary until I see what the beQuiet! AIOs offer
https://linustechtips.com/topic/612307-i3-6100-max-temp/#findComment-7914516
you're usually fine as long as it's under 90. I ran an overclocked G3258 at 4.1 GHz on stock cooling, and only hit a max of about 75 after 15 minutes of Prime95, but the i3 is a bit hotter.
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
https://linustechtips.com/topic/612307-i3-6100-max-temp/#findComment-7914522
Yeah, I can't do any testing as you can see by one of my earlier statuses but Ove setup a custom fancurve and my case fans are set to performance mode focused on CPU temps. Even at max RPMs, the Pure Wings 2 are dead silent.
https://linustechtips.com/topic/612307-i3-6100-max-temp/#findComment-7914531
