Help with CMOS clearing
Go to solution Solved by Poohl,
Clearing the CMOS is easy.
1. unplug the PC
2. Press Power Button a few seconds
3. if there is a clr_CMOS jumper connect the other two pins for a minute (on the motherboard)
    if not or you can't find it remove the Battery for a minute. (on the motherboard)
4. reassemble everything
this should kill any Password, but you may have to reconfigure the PC afterwards.
Hello people.
brief story: i bought a pre-built computer, and it works perfectly at the time, but i have a problem. I cant access to the BIOS because CMOS has a password damn the guys who built this pc. So, i wanted to enter BIOS to change the run sequence (to install a new OS) but i couldn't.
I was looking on internet about what i could do to remove the password, and i read about clearing the CMOS. Is that correct? and if it is, how can i do it correctly?
note: i tried to enter BIOS with some generic passwords, but it didn't work.
so, if you can help me with some advices, i will be very grateful.
i'll try to post a screenshot later, so you can create an idea of that i'm trying to do.
Thanks in advance :)
https://linustechtips.com/topic/612101-help-with-cmos-clearing/
1. unplug the PC
https://linustechtips.com/topic/612101-help-with-cmos-clearing/#findComment-7913271
1. unplug the PC
thanks a lot friend. but, what do you mean about reconfiguring? i will lose any data? or i need to reconfigure, for example, the run sequence if i need to do that again?
https://linustechtips.com/topic/612101-help-with-cmos-clearing/#findComment-7915581
Clearing cmos resetts all of the bios settings to their defaults, it won't mess with anything on your hdds.
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
https://linustechtips.com/topic/612101-help-with-cmos-clearing/#findComment-7915755
All your Bios settings will be set to default, usually this is no Problem, but i recommend setting a auto shutdown
temperature and maybe check the Bootorder. (Your HDD won't be touched)
https://linustechtips.com/topic/612101-help-with-cmos-clearing/#findComment-7917233
