I have an OEM Lenovo (K330A) with no BIOS control on the case or CPU fans. It's not particularly loud but I would like to lower it a bit and set it to ramp up when gaming.  Intake is 80mm PWM 0.50A Delta, exhaust is 92mm PWM 0.40A, and CPU cooler is Cryorig H7 with 120mm PWM. At the very least I would like to watch my RPM.
Black Knight-
Ryzen 5 5600, GIGABYTE B550M DS3H, 16Gb Corsair Vengeance LPX 3000mhz, Asrock RX 6800 XT Phantom Gaming,
Seasonic Focus GM 750, Samsung EVO 860 EVO SSD M.2, Intel 660p Series M.2 2280 1TB PCIe NVMe, Linux Mint 20.2 Cinnamon
Daughter's Rig;
MSI B450 A Pro, Ryzen 5 3600x, 16GB Corsair Vengeance LPX 3000mhz, Silicon Power A55 512GB SSD, Gigabyte RX 5700 Gaming OC, Corsair CX430
https://linustechtips.com/topic/611944-software-fan-controller-for-w10/
Speedfan works great for me, but its not the easiest thing to set up
5900X
MSI MEG X570 Unify
32GB DDR4 Corsair Vengeance
RTX 3080
Dark Base Pro 900
Corsair RM1000i
Thank you for the quick response.
Black Knight-
Daughter's Rig;
If you're interested in watching your system temps and other sensor data too, HWMonitor is a really handy utility
Speedtests
WiFi - 7ms, 22Mb down, 10Mb up
Ethernet - 6ms, 47.5Mb down, 9.7Mb up
Rigs
 Type            Desktop
 OS              Windows 10 Pro
 CPU             i5-4430S
 RAM             8GB CORSAIR XMS3 (2x4gb)
 Cooler          LC Power LC-CC-97 65W
 Motherboard     ASUS H81M-PLUS
 GPU             GeForce GTX 1060
 Storage         120GB Sandisk SSD (boot), 750GB Seagate 2.5" (storage), 500GB Seagate 2.5" SSHD (cache)
Type            Server
OS              Ubuntu 14.04 LTS
CPU             Core 2 Duo E6320
RAM             2GB Non-ECC
Motherboard     ASUS P5VD2-MX SE
Storage         RAID 1: 250GB WD Blue and Seagate Barracuda
Uses            Webserver, NAS, Mediaserver, Database Server
Quotes of Fame
On 8/27/2015 at 10:09 AM, Drixen said:
Linus is light years ahead a lot of other YouTubers, he isn't just an average YouTuber.. he's legitimately, legit.
On 10/11/2015 at 11:36 AM, Geralt said:
When something is worth doing, it's worth overdoing.
On 6/22/2016 at 10:05 AM, trag1c said:
It's completely blown out of proportion. Also if you're the least bit worried about data gathering then you should go live in a cave a 1000Km from the nearest establishment simply because every device and every entity gathers information these days. In the current era privacy is just fallacy and nothing more.
Thank you, I forgot all about HWmonitor, and wondered where all that info disappeared to while viewing CPUzO.o
Black Knight-
Daughter's Rig;
Speedfan. And it's easy, I don't understand peoples saying that it's hard to set up. Well, I have posted couple of "Help me" topics but it was all due to my blindness and not clicking one thing or ticking some checkbox.
I need S340. But more Define S'ish
Thank you, I will give it a try.
Black Knight-
Daughter's Rig;
Downloaded Speedfan and Its working great. CPU fan (120mm) running at 418RPM, Case running at 0RPM as I type this.
CPU fan controlled by Core 0 temp, Case fan controlled by "Temp2". Not sure if there is a better option that reports the overall temp of the CPU.
I tried to control the case fans with the GPU temp, but they go to 100% at only 50c GPU and I cant seem to adjust it. Oh well.
If anyone knows what I'm doing wrong with the GPU/Case fan deal let me know. I left OC Guru in control of the GPU fans intentionally.
Black Knight-
Daughter's Rig;
I had the same problem and that's what I mean by not being easy to set up. it is because your warning temp (or however its called) is set for 50C. When your GPU reaches that point, it will automatically set the fan to 100%. Just set it for something higher than that and youll be fine. I cant tell you where exactly it is because I wont be on my PC till Monday. If you cant figure it out by then, let me know and Ill help you ;) good luck
5900X
MSI MEG X570 Unify
RTX 3080
Dark Base Pro 900
Corsair RM1000i
Thanks I'll google for instructions.
Black Knight-
Daughter's Rig;
Set the warning temp on core1 and GPU for 70C* and set the controller for PMW2 back to GPU.  Works great and case fans ramp up with GPU temp.
Black Knight-
Daughter's Rig;
