Best GPU that doesn't require additional power?
Hey,
My friend is looking to upgrade his computer with a new GPU as his current one is atrocious.
Although, to not void his warranty he can't upgrade the PSU and so needs one that doesn't require additional power like a 6 or 8 pin connector.
We where looking at a GTX 750 ti.
Any help would be greatly appreciated,
Smiffy
4 minutes ago, Smiffy_ said:
Good point. But he does not wish to spend that much
Go for the 960 then, its cheap and light on power since that seems to be important.  (a lot lighter than R9 380.) It could make use of the Molex power, just make sure its included/bought seperately.
For the Best builds and Price lists here is a world where many points of the price have been predefined already for your convenience!
The Xeon E3 1231 V3 IS BETTER Than the Core i5 4690K and a Significantly better value for the non-overclockers or value shoppers.
The OS is like a kind food, Try it before saying if you like it or don't.
I think asus makes a GTX 950 that doesn't require aux power.
The RX 460 is also an option
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
Just a small suggestion as at these prices i would wait for the rx480 or 1060/1050 which will be cheap and may even come in a no additional power option with the new architecture requiring less power. Although i would buy a molex adapter to open your options up as they are super cheap.
Good luck on your search :)
