I started rendering a video in Sony Vegas pro 13 and I started to hear a rattling noise. I checked the fans and nothing was hitting them and it stopped when the rendering was done. Does anyone know what the noise may have been? When I render Sony Vegas uses more than 90% of my cpu which is running in turbo mode at 4.4ghz
PC Specs:
CPU: Intel i9 12900K
CPU Cooler: Corsair Hydro H150i Elite Capellix
Mother Board: MSI z690 carbon WiFi
RAM: Corsair DDR5 6400MT/S
Storage: 2TB Samsung 970 Plus NVMe, 240 SanDisk SSD Plus, Crucial MX300 750GB SSD
GPU: Nvidia RTX 3090Ti FE
Case: Phanteks NV5
PSU: Corsair RM1000X
OS: Windows 11 Home
Monitor: Acer Predator XB271HU 27" 1440p @ 165hz
Keyboard: Razer Black Widow Chroma
Mouse: Logitech G502
Sound: Sony MDR 1000x Headphones, Blue Snowball Microphone
Laptop Specs:
Gigabyte Aorus 15G
CPU: Intel i7 10875H
RAM: 16gb DDR4
Storage: 512gb NVMe, 1TB Crucial MX300 SATA SSD
GPU: Nvidia RTX 2070 Max-Q
https://linustechtips.com/topic/610570-rattling-noise-when-rendering/
5 minutes ago, Matias_Chambers said:
Could be your harddrive unless it's an SSD. What is your disk usage while rendering?
0-1%.
PC Specs:
Case: Phanteks NV5
OS: Windows 11 Home
Laptop Specs:
Gigabyte Aorus 15G
RAM: 16gb DDR4
1 minute ago, Hans Christian | Teri said:
Sounds like a bad bearing in a fan.
Do you think it is the cpu fan as the cpu is at 95%?
PC Specs:
Case: Phanteks NV5
OS: Windows 11 Home
Laptop Specs:
Gigabyte Aorus 15G
RAM: 16gb DDR4
and apart from the noise is it an issue?
PC Specs:
Case: Phanteks NV5
OS: Windows 11 Home
Laptop Specs:
Gigabyte Aorus 15G
RAM: 16gb DDR4
May be your CPU fan, may be your PSU, hard to tell from where I'm sitting. It's not really something to worry about though, the fan is not spontaneously going to break down on you. Try to locate the problem, you may want to swap it out anyways as it can be quite annoying.
Its likely fan issue. Can you run stress test and keep an eye on all fans inside the PC. Stop them with finger one-by-one to see which one is issue. It could be bad fan, loose fan or just very bad situation of case resonating.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
On ‎13‎/‎06‎/‎2016 at 3:37 PM, IBM_THINKPAD_R51 said:
Probably the CPU fan since your CPU is at 95%The fan speed will go up and the bad bearing will be more noticeable.
Thanks ill see if I can get a replacement fan for that. Ill check first to make sure it is that first
PC Specs:
Case: Phanteks NV5
OS: Windows 11 Home
Laptop Specs:
Gigabyte Aorus 15G
RAM: 16gb DDR4
I'm currently doing a stress test with prime95 and my cpu is at 100% but the fan isn't making the noise. Ill leave it a bit longer and see what happens.
PC Specs:
Case: Phanteks NV5
OS: Windows 11 Home
Laptop Specs:
Gigabyte Aorus 15G
RAM: 16gb DDR4
It started and when I stopped the fan the noise stopped so I will get a replacement fan.
PC Specs:
Case: Phanteks NV5
OS: Windows 11 Home
Laptop Specs:
Gigabyte Aorus 15G
RAM: 16gb DDR4
On ‎20‎/‎06‎/‎2016 at 10:58 PM, IBM_THINKPAD_R51 said:
@A Silver
I am glad you solved the problem. : }
Thanks for the help!
PC Specs:
Case: Phanteks NV5
OS: Windows 11 Home
Laptop Specs:
Gigabyte Aorus 15G
RAM: 16gb DDR4
