Ok, so I want to make a basic, cheap setup, and also first time working with amd, I have chosen some parts and am not 100% sure if they work.
https://www.amazon.ca/Gigabyte-Socket-D-Sub-Motherboard-GA-AM1M-S2H/dp/B00JFOFJT4/ref=sr_1_2?ie=UTF8&qid=1465694631&sr=8-2&keywords=amd+motherboard+am1
https://www.amazon.ca/Crucial-Ballistix-PC3-12800-240-Pin-BLS4G3D1609DS1S00/dp/B006WAGG14/ref=pd_bxgy_147_img_2?ie=UTF8&refRID=R65D8GVQ5N07TWYJEMHS
https://www.amazon.ca/AMD-Athlon-5350-2-05Ghz-AD5350JAHMBOX/dp/B00IOMFAQ0/ref=pd_bxgy_147_img_3?ie=UTF8&refRID=R65D8GVQ5N07TWYJEMHS
http://www.ncix.com/detail/apex-tx-519-matx-mid-tower-8d-77079.htm
https://www.amazon.com/gp/product/B00F60QH5G/ref=ask_ql_qh_dp_hza
I am completely new to amd and although:
On 6/11/2016 at 10:44 AM, Stone Ram said:
I am not a fan of amd...
I found that APUs are much cheaper than cpu plus gpu.
My thanks, Stone
https://linustechtips.com/topic/610299-checking-if-this-will-work-or-not/
1) Please change to the night theme at the bottom of the page. Then look at your post. Highlight all of it and press the icon that looks like this: Tx
2) Use http://ca.pcpartpicker.com/ to make lists as it checks the compatibility for you.
3) What do you want it to do?
USEFUL LINKS:
PSU Tier List F@H stats
Uhhh, Night theme?
And i used the pcpartipicker website and all of it is compatible. Thanks for linking it. :)
For Q3, not much really, i just want to build a computer that uses amd parts for the first time, so not something too, too intensive.
Thanks, Stone
