5 minutes ago, huilun02 said:
If you want absolute rock bottom cheapest, refer to these lists;
List of tested mobos
H81 mobos on pcpp
However if you intend to ever upgrade your Pentium to a proper unlocked i5 or i7, you will need a proper Z87/Z97 mobo.
Low end mobos have very limited capability as well, like limited RAM frequency, RAM slots, poor VRM for overclocking.
Even an G3258 at high OC cannot match a Haswell i3
And when the extra threads come into play, the Pentium will be left in the dust.
No I don't have a modern Pentium and neither do I know which 'budget' mobo will offer the highest clocks.
Silicon lottery applies regardless. YMMV.
I you don't manage a high OC, don't whine. You did cheap out after all.
Best of luck
Well thanks
