Hey everyone, iv got a few suggestions for my build and this is what i have.
Could someone look it over and check compatibility / give suggestions? I wont be overclocking
Requirements:
Budget: $1100AUD can go to $1,200Max
- Intel core
- SSD
- Wireless internet
- Case with side window (i do like this case)
- I think the rx480 looks good
- If everything is from the same store or 2stores it would be even better (because of postage).
I will be using this for
- Minecraft (modpacks 150-200mods)
- CSGO, Halo  (Mid-High Settings)
- Work, Dreamweaver, Photoshop, Web browsing.
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($275.00 @ Centre Com)
Motherboard: ASRock Z170 Pro4 ATX LGA1151 Motherboard  ($175.00 @ CPL Online)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory  ($90.00 @ Scorptec)
Storage: Kingston SSDNow V300 Series 480GB 2.5" Solid State Drive  ($159.00 @ Umart)
Power Supply: Antec High Current Gamer 520W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($104.00 @ CPL Online)
Wireless Network Adapter: TP-Link TL-WN881ND PCI-Express x1 802.11b/g/n Wi-Fi Adapter  ($19.00 @ CPL Online)
Other: Aerocool Cruisestar Windowed Mid-Tower Case - Black ($69.00)
Other: AMD RX480 ($270.00)
Total: $1161.00
Generated by PCPartPicker 2016-06-12 14:52 AEST+1000
Intel Core i7-6700K 4.0GHz Processor / Cooler Master Hyper 212X LED Cooler / ASUS Maximus VIII Hero Z170 Motherboard / TeamGroup Nighthawk 16GB (2 x 8GB) DDR4-3000 Memory / OCZ Trion 150 480GB 2.5" Solid State Drive / 2x WDBlue 500GB 2.5" 5400RPM Hard Drive (Raid 0) / EVGA GeForce GTX 1060 6GB SC GAMING Video Card / Cougar Panzar Duel Window ATX Mid Tower Case / SeaSonic 520W 80+ Bronze Fully-Modular ATX Power Supply / Microsoft Windows 10 Pro
https://linustechtips.com/topic/609982-new-build-help/
1 minute ago, Silencer said:
Motherboard. Z stands for....overclocking with a z. If you want to oc get the 6600k, if you don't stick with a H170
I'm not planing to do overclocking in my build
https://linustechtips.com/topic/609982-new-build-help/#findComment-7889728
swapped a few parts.
Motherboard: ASRock B150 Gaming K4 ATX LGA1151 Motherboard  ($158.00 @ CPL Online)
Memory: G.Skill Aegis 16GB (1 x 16GB) DDR4-2133 Memory  ($86.00 @ CPL Online)
Storage: OCZ TRION 150 240GB 2.5" Solid State Drive  ($88.00 @ Newegg Australia)
Storage: Toshiba 1TB 3.5" 7200RPM Internal Hard Drive  ($65.00 @ IJK)
Case: BitFenix Comrade ATX Mid Tower Case  ($49.00 @ Mwave Australia)
Wireless Network Adapter: Asus PCE-AC56 PCI-Express x1 802.11a/b/g/n/ac Wi-Fi Adapter  ($72.00 @ IJK)
Total: $1167.00
Generated by PCPartPicker 2016-06-12 15:01 AEST+1000
https://linustechtips.com/topic/609982-new-build-help/#findComment-7889732
Total: $1167.00
Your suggesting quite a high priced network adapter?
https://linustechtips.com/topic/609982-new-build-help/#findComment-7889746
5 minutes ago, Silencer said:
Okay from what I read no H/B choosers support +2133 RAM so I'd just get some quality 16 GB 2133 RAM.
RAM speed doesn't matter for the most part anyway
How much difference is there? is it very noticeable?
H170 then :)
Stand by while I check for RAM compatibility
Is this ASRock H170? if so which version?
https://linustechtips.com/topic/609982-new-build-help/#findComment-7889757
Suggestions? Sure!
You don't have an unlocked CPU, so pick an H110 motherboard.
Do you need 16GB of RAM? For gaming, 8GB is enough. Skylake CPUs only support 2133MHz speeds. So get a single 8GB 2133MHz RAM kit.
That SSD has numerous complaints about the memory type being changed. So get something like an ADATA, Sandisk or a Samsung SSD.
Well, if that speeds are fine for you, then I guess keep it.
Rest is good. ;)
Quote
The problem is that this is an nVidia product and scoring any nVidia product a "zero" is also highly predictive of the number of nVidia products the reviewer will receive for review in the future.
On 2015-01-28 at 5:24 PM, Victorious Secret said:
Only yours, you don't shitpost on the same level that we can, mainly because this thread is finally dead and should be locked.
On 2016-06-07 at 11:25 PM, patrickjp93 said:
I wasn't wrong. It's extremely rare that I am. I provided sources as well. Different devs can disagree. Further, we now have confirmed discrepancy from Twitter about he use of the pre-release 1080 driver in AMD's demo despite the release 1080 driver having been out a week prior.
On 2016-09-10 at 4:32 PM, Hikaru12 said:
You apparently haven't seen his responses to questions on YouTube. He is very condescending and aggressive in his comments with which there is little justification. He acts totally different in his videos. I don't necessarily care for this content style and there is nothing really unique about him or his channel. His endless dick jokes and toilet humor are annoying as well.
https://linustechtips.com/topic/609982-new-build-help/#findComment-7889768
About the wireless card, there seems to be some issues with the tp link. And ram speed won't be noticeable on the user end
EDIT:
Okay strictly speaking not true. There will be a little difference in a few tasks but for the most part 2133 and 2400 will perform very similar
https://linustechtips.com/topic/609982-new-build-help/#findComment-7889777
it has better network speeds, with ac wifi. so that you'll have a much better experience when downloading/gaming.
https://linustechtips.com/topic/609982-new-build-help/#findComment-7889806
Changed a little, dose this look better? Remember $1,100 budget (1,200Max if needed)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2133 Memory  ($95.00 @ CPL Online)
Storage: A-Data Premier SP550 240GB 2.5" Solid State Drive  ($89.00 @ Mwave Australia)
Storage: Seagate Barracuda 500GB 3.5" 7200RPM Internal Hard Drive  ($65.00 @ Centre Com)
Total: $1197.00
Generated by PCPartPicker 2016-06-12 15:27 AEST+1000
https://linustechtips.com/topic/609982-new-build-help/#findComment-7889814
Total: $1197.00
looks good, would recommend 1tb instead of 500gb but if you think its enough then sure.
https://linustechtips.com/topic/609982-new-build-help/#findComment-7889819
I have used 280Gb of storage on my laptop in maybe about 1.5years, and i can always add another if needed right?
https://linustechtips.com/topic/609982-new-build-help/#findComment-7889832
$300-320 is a bit more than what I planed to spend on a GPU.
If I used Intel's integrated graphics for now could I just slide it in later when I get it or will it require me to temperaly remove parts to be able to slide it in?
Also do I need to configure anything when I installed it?
https://linustechtips.com/topic/609982-new-build-help/#findComment-7889893
yes, just remove the pci covers in the case and fit it in. uninstall your old intel iGPU drivers before installing it to prevent driver conflicts.
https://linustechtips.com/topic/609982-new-build-help/#findComment-7889914
Get the GPU before the mass storage so you can play games comfortably:
CPU Cooler: Deepcool GAMMAXX 300 55.5 CFM CPU Cooler  ($25.00 @ CPL Online)  <<So it is quiet under load
Motherboard: ASRock H110M-DGS Micro ATX LGA1151 Motherboard  ($85.00 @ CPL Online)
Memory: G.Skill NT Series 8GB (1 x 8GB) DDR4-2133 Memory  ($41.80 @ Newegg Australia)
Storage: Crucial BX200 240GB 2.5" Solid State Drive  ($85.00 @ IJK)
Case: Deepcool KENDOMEN Red ATX Mid Tower Case  ($69.00 @ Mwave Australia)  <<Comes with five fans
Wireless Network Adapter: TP-Link TL-WN881ND PCI-Express x1 802.11b/g/n Wi-Fi Adapter  ($19.00 @ CPL Online)  <<I would not spend more unless I knew for sure this did not work
Total: $745.60
Generated by PCPartPicker 2016-06-12 16:30 AEST+1000
https://linustechtips.com/topic/609982-new-build-help/#findComment-7889943
