Hey all, my WiFi is going extremely slowly, and I don't know why. I haven't changed where it's plugged in or even touched it (except for when turning it on a few hours ago).
My download speed is only 55KB/s instead of my usually blazing fast 500KB/s! (sarcastic, but 500KB/s isn't too bad compared to what I'm currently experiencing..)
What do you think is happening? Anything I can do?
Details: Sky Broadband (not sure which package, but probably the cheapest package)
Thanks all!
(currently watching 240p YouTube on my 1080p monitor... ah bliss)
https://linustechtips.com/topic/609248-wifi-incredibly-slow/
2 minutes ago, Sauron said:
Are you sure it's the wifi connection and not your ISP being garbage?
Although it is (for lack of a better adjective) fucking shit, it's normally usable and I watch 1080p videos without buffer. On occasion I even hit 1MB/s! I looked on Sky's website, and their minimum package is 17MBps (2MB/s), which I'm definitely not getting, so yeah... What do you think could be any other issues?
https://linustechtips.com/topic/609248-wifi-incredibly-slow/#findComment-7882715
Just now, Telebubbies said:
You will have to contact your ISP for this if ALL devices connected to the router is experiencing this issue.
If it is only your pc, then there is a issue with your PC. Maybe flush dns?
Hmm, I doubt it's my PC as I only built it last week. I'll try that anyway, though.
Thanks! :)
My phone's wifi is pretty slow also, and I don't have any other devices to test the wifi on.
https://linustechtips.com/topic/609248-wifi-incredibly-slow/#findComment-7882724
Update: Just flushed dns, and I'm now getting a buttery smooth 100KB/s..!
Well it worked, I guess.. Thanks?
https://linustechtips.com/topic/609248-wifi-incredibly-slow/#findComment-7882730
Thanks! :)
Go to speedtest.net and check on both devices then. If they are roughly the same speeds (slow speeds), contact your ISP.
https://linustechtips.com/topic/609248-wifi-incredibly-slow/#findComment-7882732
Interference or a very bad router. I'm betting on the ISP though. And I do think you meant 1Mbit/s ;)
sudo chmod -R 000 /*
https://linustechtips.com/topic/609248-wifi-incredibly-slow/#findComment-7882744
3 minutes ago, Telebubbies said:
How much Mbps are you paying for? 100kbps is pretty slow.
Ah ok, just done the test on my phone.
PC results: 34ms, 1.48MBps D/L, 0.11MBps U/L
Phone results: 33ms, 1.65MBps D/L, 0.65 MBps U/L
Doesn't look like it's my PC as the results are fairly close and they were 2-3 min apart.
https://linustechtips.com/topic/609248-wifi-incredibly-slow/#findComment-7882764
The speed seems good then.
https://linustechtips.com/topic/609248-wifi-incredibly-slow/#findComment-7882773
1 minute ago, CandleJakk said:
Good? I should have phrased it differently, I meant 1.48 Megabits per second, aka 0.185MB/s D:
Just done the test again and got 174ms, 0.15MBps.
Oh joy.
The connection is sh!t. But 100kbps with 1.5Mbps is good.    But is is still terrible to others.
https://linustechtips.com/topic/609248-wifi-incredibly-slow/#findComment-7882806
