Hi guys,
So I went for my driving lesson this morning and left my phone at my house.
I came back, had some lunch and went to use my S4. The battery was critical so I plugged it in. It would not charge, so I took the battery out and put it back in to see if that would work; it didn't. I plugged it into my pc to try and charge it that way, my PC detected the S4 but not correctly I don't think (said unrecognised but my PC does that sometimes). The phone just vibrated every 10-15 seconds and came up with the emtpy battery with the white circle in it.
I unplugged the phone from my PC and took it downstairs to try another USB adaptor I have. Plugged it in, turned it on AND THE S4 STARTED HISSING. What the hell is going on guys?!
When you play The Game of Thrones, you win or you die...
https://linustechtips.com/topic/60904-holy-s4-problem/
Have you accidentally mistaken your phone for a hockey puck in the past few days?
Take it apart leave in overnight in a bag of rice
Big Bertha3570k @ 4.5GhzASRock Fatal1ty Z777970 DCUII TOP EVGA GTX 780Swiftech H220 w/ NF-F1216GB RAM128GB Kingston HyperX 3K1TB Western Digital Black40GB Western Digital Raptor 10K PeripheralsMionix 3200 MouseCMStorm Quickfire Rapid w/ Cherry MX Blues2 x Dell U2713HM AudioAsus ROG Orion Pro HeadsetSony XB-500AKG K240Bose AE2i​Fiio E10
Samsung Galaxy S45.0" 1920x1080p Super AMOLED screen16GB Storage2600 mAh battery1.9Ghz quad-core Krait CPU2GB RAMCyanogenMod CameraNikon D310018x55mm NIKKOR VR Lens14.2 MP
https://linustechtips.com/topic/60904-holy-s4-problem/#findComment-828630
Nope, It's broken. RMA it.
Edit: or kick up a massive stink with samsung and say it could've caught fire and burned your house down, threaten going to the press etc.
Milk this and see what free stuff you can get, ROFL. Samsung have some awesome product lines
https://linustechtips.com/topic/60904-holy-s4-problem/#findComment-830391
Hopefully EE (T-Mobile) will take it and repair it. I'm an electrical engineer in training and this has all my coursework and photos on it. The only way I can think of is putting a charged battery in the phone, somehow backing it up from there perhaps using dropbox or kies (no idea what kies is). Then it'll be much less stress.
https://linustechtips.com/topic/60904-holy-s4-problem/#findComment-830648
Yeah. Get some answers from Samsung. Your particular item number shouldn't have gone past quality control.
Its what you get unfortunately for buying cheap plastic products. Shoulda got a HTC One or an iPhone
You need to grow out of you mental state.
PC: The Oracle
Phone History: Nokia 3310, Samsung Z500, HTC Touch, iPhone 3GS + Samsung S5600 Preston, iPhone 3GS + Blackberry Bold 9700, Samsung Galaxy S + Blackberry Bold 9700, Samsung Galaxy S2 + Samsung Galaxy Tab + Blackberry Bold 9700, Samsung Galaxy S3 + Blackberry Torch 9800, Samsung Galaxy Note 2 + Blackberry Bold 9900 + Blackberry Playbook, Samsung Galaxy Note 2  + Nokia Lumia 920, Galaxy S4 +Nokia Lumia 920, Samsung Galaxy S4, Samsung Galaxy Note 3, Samsung Galaxy S5
https://linustechtips.com/topic/60904-holy-s4-problem/#findComment-833126
Hahaha you know its true though. Samsung make crap phones. Only HTC and Lumia and iPhone are worthy
I sense a hater coming on.
https://linustechtips.com/topic/60904-holy-s4-problem/#findComment-835161
yeah. I think is a build material elitist. Plastic and metal is high quality. What the difference is in is the build material. No manufacturer will let quality management pass a crap quality phone.
Sent from my SM-N9005 using Tapatalk 4
PC: The Oracle
https://linustechtips.com/topic/60904-holy-s4-problem/#findComment-835202
Shut up you idiot.
My step-dad took the battery to work today to get his friend to charge it and it wouldn't hopefully it's the battery.
Again, shut up you clearly know nothing if you think that either a Windows phone or Apple product are better. Also you are reported, you have clearly come onto this thread of my plea for help to come and gloat about the supposed quality of Apple's phones.
https://linustechtips.com/topic/60904-holy-s4-problem/#findComment-839187
Shut up you idiot.
he usually goes around samsung threads spewing hate comments that dont help the OP. He is less than a fanboy. He is a hater. I reported him too for hating samsung without reason out of pure hatred. I hope the mods check him out.
PC: The Oracle
https://linustechtips.com/topic/60904-holy-s4-problem/#findComment-839219
  • 5 months later...
Shut up you idiot.
If your battery works, then clean the USB port. USB port got dirty after using.
And check the connector of battery , connector & flex cable of USB port.
Or you can try to replace a usb port flex cable.
If it still can't work, it may be the charge ic on the mother board broken.
https://linustechtips.com/topic/60904-holy-s4-problem/#findComment-1707856
