Python Program not reasigning variable when if statement run
Solved by fizzlesticks,
The problem is in the line
pi = int(4*(withinone/loop))
withinone and loop are both integers so it does an integer division, which in your case is resulting in 0. To do a floating point division you'll need to cast one or both of those variables to a float. You'll also probably want to remove the int cast.
