Looking on amazon for a decent mouse. Found a few cheaper options, what do you guys think?
http://www.amazon.com/Sentey-GS-3521-Aphelion-Buttons-Selector/dp/B00RN7QSJ0?ie=UTF8&keywords=gaming mouse&psc=1&qid=1465495007&ref_=sr_1_1&sr=8-1-spons
http://www.amazon.com/Redragon-CENTROPHORUS-2000-Gaming-Buttons-Weight/dp/B00HTK1NCS?ie=UTF8&keywords=gaming mouse&qid=1465495007&ref_=sr_1_3&sr=8-3
http://www.amazon.com/HV-MS672-Ergonomic-Soothing-Colors-Buttons/dp/B00KKAQYXM?ie=UTF8&keywords=gaming mouse&qid=1465495007&ref_=sr_1_5&sr=8-5
http://www.amazon.com/Zelotes-Button-Optical-Wired-Gaming/dp/B00IFRH6JS?ie=UTF8&keywords=gaming mouse&qid=1465495007&ref_=sr_1_6&sr=8-6
http://www.amazon.com/TeckNet-Raptor-Gaming-Button-Weight/dp/B00E290JRE?ie=UTF8&keywords=gaming mouse&qid=1465495007&ref_=sr_1_7&sr=8-7
A lot of options here all look pretty good, what do you guys think? I chose like the first top 5 high rated ones, I don't care if its chorded, got extra USB in my pc so no big deal there, price is good, and they all look decent. But I don't know much about DPI, what is a decent number for a medium-ish PC gamer? (I play games like the world of tanks/planes/warships, warcraft, D3, MMO's, stuff like that)
Jesus is the way, the truth, and the life.
Please Quote me when replying.
CPU
 - Ryzen 7 5800X3D | RAM - 32GB DDR4 4000Mhz | MB - MSI B550 A-PRO | Boot - 2TB NVME 980 Evo Plus | GPU - EVGA FTW3 RTX 3090 24GB
https://linustechtips.com/topic/608698-help-pick-a-mouse/
A little pricey. I'm leaning toward this one because its only 8 so even with the massive 8$ shipping its only going to be 16$, and it has a higher DPI then the roccat. http://www.amazon.com/HV-MS672-Ergonomic-Soothing-Colors-Buttons/dp/B00KKAQYXM?ie=UTF8&keywords=Gaming mouse&qid=1465495258&ref_=sr_1_5&sr=8-5
CPU
https://linustechtips.com/topic/608698-help-pick-a-mouse/#findComment-7877213
Any other opinions? I am about to purchase and would like more thoughts. I checked out the sentry above commentor suggested and it looks ok but my costly, I suppose I am willing to spend a bit more if it means a better difference.
CPU
https://linustechtips.com/topic/608698-help-pick-a-mouse/#findComment-7878351
Nvm I chose the sentey because it looks like it might be more comfortable on the hand.
CPU
https://linustechtips.com/topic/608698-help-pick-a-mouse/#findComment-7878396
