the best way for my case
G-1400
Hello
I have NZXT phantom-410
and it already came with 3 fans
one on the front (in)
one on the top rear (out)
one on the rear (out)
it is -ve pressure and i love in really dusty area so and i want it neutral.
I need your advice..
where do i need to put the fan? and which size?
thanks in advance
I'd just move the top fan to the front of the case as an intake
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
thanks for your answer
but the top fan is 140mm an the front can only get either two 120mm or one 140mm..so
Get dust filters for your intakes. Positive or negative airflow doesn't matter if you're not using filters.
