When my PC in completely turned off i press the button to turn it on. it turns on for about 2 seconds and turns off for 5 seconds. then turns on for 5 seconds and turns off for another 5 seconds. and on the third try it boots to the bios and windows with no errors or anything else.
I'm not sure what's going on.
I have no stability issues or failures it's only during boot.
Specs:
FX6350 @ 4.7Ghz
Gigabyte 990FX ud3
700W thermaltake toughpower PSU (this is not it I've tried others)
Kingston hyperX 3k (120GB)
amd HD6450 1GB
I'm thinking it may be something in the bios but I'm not sure. Any guesses?
TekSyndicate Forum Moderator: https://forum.teksyndicate.com/users/njm1112
5930K@4.3Ghz | 16GB 4x4 2133Mhz | r9-290 | 6TB Raid5 | 250GB 850Evo | 8.1pro | RM750
https://linustechtips.com/topic/60825-weird-pc-boot-problems/
That'd be my first course of action.  Possibly resetting the bios by removing the battery/shorting the jumpers as well.
Try resetting your overclock and see if that helps. Same thing happened to me when i oc'd my ram and cpu
Intel 4670K /w TT water 2.0 performer, GTX 1070FE, Gigabyte Z87X-DH3, Corsair HX750, 16GB Mushkin 1333mhz, Fractal R4 Windowed, Varmilo mint TKL, Logitech m310, HP Pavilion 23bw, Logitech 2.1 Speakers
https://linustechtips.com/topic/60825-weird-pc-boot-problems/#findComment-827427
I forgot to say my ram-
8GB of 1866Mhz cas 9 (9-10-10-27) patriot viper.
CPU-Z confirms it's running @ spec
https://linustechtips.com/topic/60825-weird-pc-boot-problems/#findComment-827461
just try everything @ default like everyone suggests, otherwise it could be a faulty mobo, or ram. Also have you ever updated your BIOS?
Case Bitfenix Ghost, Mobo Asus Maximus VIII Ranger, CPU i7 6700K @4.2 Ghz cooled by Arctic cooling Freezer i30, (barely). GPU Nvidia GTX 970 Gigabyte G1 @1519Mhz core, RAM 16Gb Crucial Ballistix CL16 @2400Mhz. SSD 128GB Sandisk Ultra Plus as my OS drive. HDD's  1TB  Seagate ST31000524AS its OEM, 3TB Seagate Barracuda, 2x 500GB WDC Blue (RAID 0)
If it isn't working absolutely perfectly, according to all your assumptions, it is broken.
https://linustechtips.com/topic/60825-weird-pc-boot-problems/#findComment-827569
No force update. Just out of the box.
https://linustechtips.com/topic/60825-weird-pc-boot-problems/#findComment-827598
Try and see if setting the ram speed a little lower does anything. Could be bad memory.
It worked fine before. But when i went into the bios to change somethings (preping for OC more or less) then it started doing it. So I'm fairly certain it's soft/firmware not hardware.
https://linustechtips.com/topic/60825-weird-pc-boot-problems/#findComment-827607
Good ideas. I'll reset things to zero and see how it goes. I can't shut down and do it now though. I'll have an update tomorrow.
https://linustechtips.com/topic/60825-weird-pc-boot-problems/#findComment-827611
Go ahead and update the bios if you think it's firmware. It's most likely a semi-stable overclock that finally showed its rear end.  And yes, I would recommend resetting your bios and starting from square one. Good luck man.
I'm still not able to shut it down at this moment but I know it's not the OC. 4.7 is stable at different Voltages and it can handle 4.8 and possibly 4.9
https://linustechtips.com/topic/60825-weird-pc-boot-problems/#findComment-828869
I resest the Cmos and the bios.
Working Fine.
I bumped my cpu ratio back to 23.5 (4.7Ghz) and it's running fine. I must've messed with a different setting and freaked it out but it's fixed.
Thanks guys!
https://linustechtips.com/topic/60825-weird-pc-boot-problems/#findComment-829744
