more options and better confiurations ex: you don't need a i7 and a gt740
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/607996-help/#findComment-7869971
1 minute ago, Gino942 said:
i already said that but thanks!
not in the OG post.
https://linustechtips.com/topic/607996-help/#findComment-7869981
Just the typically excessive fees, markups, and tricks/snake oil. Honestly, not everyone should build their own, but aside from the cost mark up
Often not overclocked, if it is its not to the best it could be
mismatched parts for gaming, no game needs an i7 6950x
snake oil, 'gaming ram' is not a valid product
lights!!!! alot of prebuilt systems offer looks over performance
meaningless features, 'super fast thunderbolt' isn't needed for desktop gaming
                   _/ V\
    ______|   __/_/| |
   /_______\______}\__}
[I5-12600k | 32gb DDR5 6000 | RTX5070 | 2x1tb M.2]
[Ryzen 5 1600 | 16gb DDR4 3200 | GTX1030 | 4x 8tb HDD]
https://linustechtips.com/topic/607996-help/#findComment-7869982
A few points:
  • You can customize it how you want (color scheme, something crazy like a desk pc, watercooling loops as you desire, the list goes on).
  • It's generally much cheaper
  • You can research the components before hand to ensure you're buying good quality ones - prebuilt PC's save by skimping on some crucial components such as PSUs, SSD's, motherboards
    • Buy an unlocked processor so you can overclock and get more performance for your money
    • Same goes for memory/graphics card
  • The experience - it's quite straight forward to build your first PC and it opens a whole world of ideas
  • You can upgrade whenever you want; if you can build your own PC, you can sure as hell upgrade a PC's components.
  • When you buy prebuilts, it comes with a shit load of bloatware. I know this is an easy fix, but still, who likes bloatware?
"The only person you are destined to become is the person you decide to be."
CPU: Intel i5 4690K - Motherboard: Asus Maximus VII Ranger - RAM: Corsair Vengeance LP - 2x4GB @ 1866Mhz - GPU: MSI Twin Frozr GTX 770 4GB - CPU Cooler: Be Quiet! Dark Rock Pro 3 CPU Cooler - PSU: EVGA SuperNova G2 750W - Storage: Seagate Barracuda 2TB HDD- Case: Fractal Design Define R4 Windowed (with Red AKASA Led Strips) - Display: Benq GL2460HM 24" Monitor
https://linustechtips.com/topic/607996-help/#findComment-7869986
Well you certainly chose an interesting topic. Here are some ideas.
  • Low quality. Pre-builts are often throwaway because they are usually outdated and use bottom end components. This goes without saying, but they cost too much.
  • Flexibility. You can build a computer to your use-case scenario.
  • RMA. Quite often components individually have better warranties and this also allows you to send them back individually meaning you may still be able to use your computer during that period of time.
  • Upgrades (flows on from point 1). Building your own computer gives you the ability to upgrade individual components as they go bad or exceed their usefulness which may not be possible on a pre-built due to proprietary connectors, cheap and barely adequate power supply or even a case that is of inadequate size or airflow.
  • Knowledge. Building a computer encourages you to understand the internals a bit better gives you the ability to troubleshoot yourself. Also small things such as knowledge of driver updates resulting in decent performance increases for free which an uninformed user would not know about.
  • Resale. Owning a pre-built computer will encourage a user to use it until it comes to a point where the computer is unusable. This is a result of the exorbitant pricing and the large upfront cost of having to buy a whole computer in one purchase. At this point the computer is barely worth selling compared to someone who sold individual components as upgrades were needed.
CPU - Ryzen Threadripper 2950X | Motherboard - X399 GAMING PRO CARBON AC | RAM - G.Skill Trident Z RGB 4x8GB DDR4-3200 14-13-13-21 | GPU - Aorus GTX 1080 Ti Waterforce WB Xtreme Edition | Case - Inwin 909 (Silver) | Storage - Samsung 950 Pro 500GB, Samsung 970 Evo 500GB, Samsung 840 Evo 500GB, HGST DeskStar 6TB, WD Black 2TB | PSU - Corsair AX1600i | Display - DELL ULTRASHARP U3415W |
https://linustechtips.com/topic/607996-help/#findComment-7870315
