ok so my external hard drive just turned all my photo files into shortcuts and just deleted everything automatically i didnot do anything. all the files just disappeared but the drive still says that it has 300gb used of 1tb storage pls hep so i dont know if i can recover them or if the drive is faulty pls help
https://linustechtips.com/topic/607973-external-hard-drive-problems/
That reminds me of a certain cryptolocker virus (which doesn't actually encrypt anything, it's just to fool people)
What if you change the extension back to the original extension?
(I assume they were actual pictures, not just shortcuts originally)
Could also be a symptom of a faulty drive, but not a very common one.
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
as @HPWebcamAble said, this sound like some danky virus.
You might try changing the extensions, or look to where the short cuts go. Have you made sure you are showing hidden files?
Have you seen any strange files/scripts/txt files?
                   _/ V\
    ______|   __/_/| |
   /_______\______}\__}
[I5-12600k | 32gb DDR5 6000 | RTX5070 | 2x1tb M.2]
[Ryzen 5 1600 | 16gb DDR4 3200 | GTX1030 | 4x 8tb HDD]
