Hey guys. few days ago i had a power cut in my area, after i got the power back i go on my pc and my my displays were messed up. i cleaned them up but while i was doing that i noticed that my monitor refresh rate was 120 and before the power cut it was 144. i tried looking around in the nVidia control panel if i can change it back but i found nothing.. wondering if you guys could please help me out? i bought this monitor not for it to be 120hz but 144 and i feel really annoyed. any advice is appreciated.
https://linustechtips.com/topic/607694-help-plz/
maybe try using this to set a custom resolution.
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/607694-help-plz/#findComment-7866827
4 minutes ago, Lolucoca said:
According to how the Monitor is shown in Windows, either via VGA or DVI
I have a retired SP4 next to the bed for the morning.  I didn't look at the picture good enough.
VGA shouldn't be an issue, but he should have this connected via DP.
https://linustechtips.com/topic/607694-help-plz/#findComment-7867814
