1 minute ago, Devara.A.Z(Dv) said:
i kinda need some help,i saw on linustechtips video about the GTX 1080 and i kinda surprise when i saw a cable to connect graphic's card from motherboard,what is the cable name?,i cant find it
From the motherboard..? A picture would be helpful.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/607619-graphics-card-cable/#findComment-7865983
5 minutes ago, Devara.A.Z(Dv) said:
i cant find the picture i have to search it from linus video
There's no cable that connects from the motherboard to the GPU. There is the power cable that connects form the power supply to the GPU though. It looks like this: http://www.google.com/search?q=pci-e+power+cable&safe=off&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwiLn_fX45XNAhUFEiwKHdPtC7oQ7AkIJg
https://linustechtips.com/topic/607619-graphics-card-cable/#findComment-7865995
7 minutes ago, Devara.A.Z(Dv) said:
no,there is i saw one of the video between linus and hardwarecanuck video,like a gpu sleeve cable from gpu ports on the mother board to the gpu
Like this?
http://i01.i.aliimg.com/img/pb/581/972/398/398972581_009
USEFUL LINKS:
https://linustechtips.com/topic/607619-graphics-card-cable/#findComment-7866000
yess
That is a PCI-E Riser cable that allows you to distance the GPU (or any PCI card) from the motherboard for unique orientations (like sidemounted GPUs in the Lian-li PC-07S case).
Would recommend getting a shielded one from 3M for $100 as the other ones can have serious performance hits.
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
https://linustechtips.com/topic/607619-graphics-card-cable/#findComment-7866013
i just found the picture
https://linustechtips.com/topic/607619-graphics-card-cable/#findComment-7866016
THANK YOU VERY MUCH,
https://linustechtips.com/topic/607619-graphics-card-cable/#findComment-7866020
