Does anybody know what this usb drive came formatted with by default? I reformatted it for mac to I could install mac osx, then reformatted it back, not being sure which format it was before, I did exfat. But now my speeds are terrible.
CPU: Intel i7-3770k at 4.8Ghz  CPU Cooling: 320mm UT60  Motherboard: MSI Z77A-GD55  RAM: G.Skill Ripjaws X Series 16GB 2133Mhz (2x8GB)  SSD: Intel 330 Series 120GB  HDD: WD 1TB Caviar Green  GPU: EVGA GTX 780 x2  Sound Card: Creative Recon3D  PSU: Raidmax RX-1000AE 1000W  Case: Arc Midi R2  Monitor: Benq XL2420T at 129Hz  OS: W8 64Bit  Keyboard: Razer Blackwidow 2013 Ultimate  Mouse: Logitech MX518  Mousepad: Steelseries QCK+  Headset: Turtlebeach X12 (Temp.)
https://linustechtips.com/topic/60747-need-help-reformating/
My guess is FAT32
https://linustechtips.com/topic/60747-need-help-reformating/#findComment-826267
Isnt fat32 the one that cant write files over 4gb?
https://linustechtips.com/topic/60747-need-help-reformating/#findComment-826271
Fat for 2GB or lower
Fat32 for 4GB-32GB
exFAT for 64GB and higher
MOAR here -> http://kb.sandisk.com/app/answers/detail/a_id/312/~/formatting-a-memory-card,-flash-drive-or-device-using-a-pc
<p>Eryi's Action Rule#2 - "Dont jump on the green mushroom"
Ministry of StopIt!
https://linustechtips.com/topic/60747-need-help-reformating/#findComment-826277
I doubt it was formatted with Fat32, as I had written files that are 8gb to the drive before.
https://linustechtips.com/topic/60747-need-help-reformating/#findComment-826286
