I'm working on a project where I put three separate systems in one case. It's kind of like Linus's 2 gamers 1 CPU but for people who don't have the money for $1,000 10 core CPU's when you can buy 2 5820Ks for $600. Currently, I have decided to make it a triple system build as one will run Windows, one will dual boot Linux/Windows, and the last will be a Hackintosh. A dual system is easy enough when it comes to fitting the motherboards in but now that this is a triple system I cam trying to think of creative ways of doing this. All the motherboards are ATX (one is E-ATX) so something like the HAF stacker is out of the question. Will be Watercooling so that will help when it comes to fitting everything and I was planning on doing an upward airflow system with the radiators at the top so anything that needs air for cooling will get it. I have thought about having the Hackintosh simply run integrated graphics but I'd like it to be able to do some heavy video editing so that is out of the question. I have three PSU I had been planning to use but I'm not sure how to fit them in the rig. As for the graphics cards I was planning to use PCIE extensions and lining them up at the top under the radiators with their water blocks. But the motherboards is where I'm really running into difficulties. In a dual system I would just have one regular and the other inverted but with three it becomes a challenge. I was planning on mounting them horizontally with the IO pointed toward the front and side of the case with a small door I could mount magnetically housing the IO.
Do you have any ideas for arranging the PSU's, mobo's, or anything else that would help?
https://linustechtips.com/topic/607410-triple-system-chassis-project-thoughts/
how about one mobo on the case floor and two on the mobo tray?
two PSU's behind the mobo tray and one on the floor
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
I had thought about that but how would airflow get to the motherboard on the floor? I was planning to have air flowing in from the floor.
@Johnmakuta FYI a lot of graphics cards are very hard to use in a hackintosh, and id recommend putting all the psus on the bottum in a row, then 1 mini itx in regular mobo tray but keep it as far away from the graphics card I/O holes , one mini itx  parallel from the other one (use a motherboard tray and mount it), and one mounted below the one on the non motherboard tray sides,  you can use extensions to connect all the motherboard ports to the outside, like luke did in his fallout build, use 2.5inch hdds or ssds and mount them all behind the motherboard tray, put all the GPUs where they regularly go in a typical build and use pci-e extensions
Omega-  I5 6600k | Gigabyte GTX 1060 | Cougar Panzer | DDR4 16GB 3000MHz | MSI Z170 Gaming M5
               EVGA 650 GQ | AOC 60Hz Freesync Panels x2 | AOC 144hz Freesync Panel x1
Epsilon- I7 2700k | Asus GTX 970 | Corsair 780t | DDR3 8GB 1600MHz | EVGA Z68 FTW Mobo
               Corsair 750W G2 | Acer R240HY x2
Upsilon- i7 5500u | 6GB DDR3 | 720p 60Hz panel
As I mentioned before, I only have ATX boards. Thanks for the tip on the Hackintosh.
Oh sorry i didnt notice the atx thing, and btw if you want to either buy a preflashed mac card or have your card mac flashed you should go to http://www.macvidcards.com/
  • 4 years later...
https://m.de.aliexpress.com/item/1783227644.html?trace=wwwdetail2mobilesitedetail
Something like this I know im late but if anyone else is doing this
