The motherboard graphics aren't working when i plug my monitor into it. I would like to have my iGPU take care of my second monitor so my GTX 970 doesn't have to use the extra VRAM and power to render a second display (since I don't use it for gaming). I was looking for suggestions to get that working.
CPU Ryzen 5 3600 | Motherboard MSI B550 | RAM 32 GB Corsair Vengance Pro | GPU EVGA GTX 980ti | Case Corsair 4000X | Storage Seagate Barracuda 2TB HDD,  Team GX2 1TB SSD | PSU Sentey 850w 80+ Bronze | Cooling AMD Wraith RGB | PCPartPicker URL https://pcpartpicker.com/list/RN7kGc |
https://linustechtips.com/topic/606489-i5-4690k-igpu-issues/
1 minute ago, ShadowTechXTS said:
Enable iGPU multi monitor in the BIOS.
ok thanks. I've been trying to download and install drivers and it still doesn't work. That would make sense to enable it in the BIOS.
https://linustechtips.com/topic/606489-i5-4690k-igpu-issues/#findComment-7854633
My BIOS doesn't have an option for that. I have an ASUS Z-87A NFC Edition btw.
https://linustechtips.com/topic/606489-i5-4690k-igpu-issues/#findComment-7854655
It should be in there somewhere.
No not in the OC section or in the CPU section. It does say "CPU Graphics speed : ?" (I forgot the speed)
https://linustechtips.com/topic/606489-i5-4690k-igpu-issues/#findComment-7854676
ASUS Z87-A (NFC Edition) user's manual >> Chaper 2: BIOS Information, page 2-30.
Quote
Graphics Configuration
Primary Display [Auto]
Allows you to select the primary display from iGPU, PCIE and PCI Graphics devices.
Configuration options: [Auto] [iGPU] [PCIE] [PCI]
iGPU Multi-Monitor [Disabled]
Allows you to enable the iGPU Multi-Monitor. The iGPU shared system memory size will be fixed at 64MB.
Configuration options: [Disaabled] [Enabled]
The exact settings should be located under:
Advanced >> System Agent Configuration >> Graphics Configuration
Hope this helps...
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/606489-i5-4690k-igpu-issues/#findComment-7855038
Hope this helps...
ok cool, thanks. I turned on iGPU multi monitor. however when i plug in my display it says "no signal". Now do i get drivers?
https://linustechtips.com/topic/606489-i5-4690k-igpu-issues/#findComment-7857021
