Is it possible for this mobo to power all these fans
Alright, I was looking into building a desktop and the mobo I was looking into people say it only supports "1 CPU fan + (2) chassis fans" and I was planing on having 2 or 3 Corsair air series AF120 LED quiet edition Fans a Cooler Master Hyper 212 EVO CPU cooler with 120mm fan, which by the way I was wondering if I could replace the fan with one of the Corsair ones I just mentioned plus the case has a 200mm fan on the front is it possible to have the 200mm one 2 of the Corsair ones and the CPU one all powered with this mobo
here's some links to the products
Mobo http://www.amazon.com/dp/B017NMX6JO/?tag=pcpapi-20
Corsair fans http://www.amazon.com/Corsair-AF120-Quiet-High-Airflow/dp/B00F6S10KK/ref=sr_1_3?s=electronics&ie=UTF8&qid=1465074794&sr=1-3&keywords=corsair+air+series
Case http://www.amazon.com/dp/B00PDDMN6S/?tag=pcpapi-20
CPU Cooler http://www.amazon.com/dp/B005O65JXI/?tag=pcpapi-20
DeepCool PWM Fan HUB.
Main gaming pc: Lian-Li Lancool II Mesh Performance - Ryzen 5 5600X - MSI GTX1080Ti Armor - AMD Wraith Spire RGB - ASUS TUF Gaming B550 Plus - Corsair Vengeance RGB PRO 2x8GB 3200MHz - 500GB M.2 (and a few other drives)
Gaming laptop: ASUS GL552VW: i7 6700HQ - GTX960M 2GB - 8GB DDR4 2166Mhz RAM - 1TB 7200RPM HDD
and your sure that would work with AF fans also I read that using a splitter on it could overload the circuit with splitter
How much do you want to spend? And which case do you have?
EDIT: Oh sorry, you posted a link of your case, I thought I saw it on another post.
Some options:
-NZXT Grid+ V2
-NZXT Grid ten port fan hub
-Phanteks PWM fanhub
2 minutes ago, Sterling Archer said:
I meant to click informative not funny thanks for the help
Lol, you could remove the 'Funny' reputation by going over List and clicking the X next to your name, then click informative again ;D
