Theres not much out the better than a 950pro to be fair.. If the board has a M.2 slot it will go straight in but you can get a pcie adapter like this if not or your M.2 slot is the older slower speed.
http://www.watercoolinguk.co.uk/p/ASUS-Hyper-M2-X4-Mini-PCIE-adapter-card-black-PCB_55765.html?gclid=CL7P0eiGjM0CFRK3GwodCwkIQA
Ive just got the SM951, specs not to far off the 950pro but no V-NAND, cheaper than a 950pro though.
Also 950 Pro is NVME, so unless your motherboard supports booting from NVME it wont work as a boot drive.
X99-A
32Gb/s ultrafast M.2 x4
https://linustechtips.com/topic/605632-samsung-950-pro/#findComment-7846626
