What are you gonna do with the build? What about peripherals? What games will you be playing? Planning to stream, video and picture editing? Do you wanna max out all games or are you fine with lowering some settings to save a few bucks. We need more info to help you mate. MOAR INFO! :)
I once explained to my girlfriend what true love is. I said, "If you were a shit, I'd put you back in" and to this day, she is still my little shit.
https://linustechtips.com/topic/605541-please-help/#findComment-7845182
I am going to be gaming I already have peripherals and I will be planning to play like cs (would like to record it just for them siq faze 360 mlg noscopes) I am willing to save money in anyway possible. I am also fine with waiting for like the new GPUs to come out since I plan to build it around christmas
https://linustechtips.com/topic/605541-please-help/#findComment-7845233
Do you have a monitor, is it more than 60hz? What resolution? And also, waiting for the new GPU would be a good idea, so its good that you are willing to wait.
https://linustechtips.com/topic/605541-please-help/#findComment-7845245
6 minutes ago, siq memes lmao said:
Lmao only 60hz monitor 1080p
Forgot to mention when playing CS I downscale to 4:3 1024x768
https://linustechtips.com/topic/605541-please-help/#findComment-7845263
Where are you from? So we can use the right pc-part picker thingy. Also do you plan to do any overclocking? And do you want something easy to move around or will it mostly be standstill/not often moved?
https://linustechtips.com/topic/605541-please-help/#findComment-7845331
CPU: Intel Core i5-6400 2.7GHz Quad-Core Processor  ($258.00 @ Centre Com)
CPU Cooler: Cooler Master Hyper T4 70.0 CFM Rifle Bearing CPU Cooler  ($33.00 @ CPL Online)
Motherboard: MSI B150M BAZOOKA Micro ATX LGA1151 Motherboard  ($119.00 @ IJK)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2133 Memory  ($95.00 @ CPL Online)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($68.00 @ CPL Online)
Video Card: Gigabyte Radeon R9 380 4GB SOC Video Card  ($319.00 @ Mwave Australia)
Case: Cooler Master N300 ATX Mid Tower Case  ($55.00 @ CPL Online)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply  ($79.00 @ PCCaseGear)
Total: $1026.00
Generated by PCPartPicker 2016-06-03 19:06 AEST+1000
That's the best I can do for you for now.
I'm at school, so don't have much time.
But that should give you a good look at what is possible with your budget.
https://linustechtips.com/topic/605541-please-help/#findComment-7845336
Total: $1026.00
Wow you came in fast
https://linustechtips.com/topic/605541-please-help/#findComment-7845339
That build there is as good as any. I would look into an SSD for a boot drive though and throw in an extra tb on the harddrive just because it saves you money to go for 2tb instead of one if you look at dollar spent per GB. I'll cook up a list soon and see if I can fit it in your budget, but then again, that would be pushing it.
https://linustechtips.com/topic/605541-please-help/#findComment-7845347
I have a WD external HDD (3tb) for anything that doesn't really need to be run on the computer so like photos and videos and screenshots and crap
https://linustechtips.com/topic/605541-please-help/#findComment-7845351
Memory: G.Skill Ripjaws V Series 8GB (2 x 4GB) DDR4-2133 Memory  ($51.00 @ CPL Online)
Storage: Samsung 850 EVO-Series 120GB 2.5" Solid State Drive  ($85.00 @ Storm Computers)
Total: $1034.00
Generated by PCPartPicker 2016-06-03 20:17 AEST+1000
I decided to remove the cooler because you simply don't need it, I also changed out the ram to an 8gb kit because I figured you won't need more, atleast not right now, and ram is the easiest things to upgrade so we don't need the 16gb kit now. I also went ahead and added an SSD for boot and perhaps a few games. What you do with storage is up to you, in my defense I simply can't live without my SSD but if you've never had the joy of having one you can just go along your way because ignorance is a blizz :P This build should be able to run CSGO perfectly and many other games, I don't know about the case thermals, but the stock cooler should do as a start. Also, with the new 480 from AMD coming in a price of $199 you will save some money there and can either upgrade some stuff or leave it be and save your hard earned money. (Or your mom's credit card)
https://linustechtips.com/topic/605541-please-help/#findComment-7845575
Total: $1034.00
haha thanks for this I will see what I can do probably will switch out the gpu with the 480 cuz $ per fps is important to me since I don't think I will be able to build this till christmas that gives time for the 480 to come out :)
Yeah I like the idea of the SSD for boot drive and shit
https://linustechtips.com/topic/605541-please-help/#findComment-7849163
