Hi, posting for a friend. He was working with a video in Premiere Pro, and he used the 720p Youtube video setting to export. He accidentally selected the original raw file to write over. It then gave him an error, and now the file says size: 0 bytes and refuses to be used for anything. Any way to recover this or is he screwed?
Lenovo Ideapad 720s 14 inch ------ One day I'll have a desktop again...
https://linustechtips.com/topic/605462-please-help-corrupted-data-recovery/
I doubt it would have overwritten the original footage since they would almost certainly be different file extensions and thus different names... are you absolutely sure that's what happened?
As far as he says. I think that when he was selecting where to save the export he selected the original footage (like, actually clicked on it) and then hit export so it copied over. TBH I'm not sure what you mean by file extensions.
Well there is a good chance that part or all of it is gone but you could try some data recovery software
Okay, what would you recommend that's free  (this isn't a huge deal but he would like it back).
I don't have personal experience with them but this is generally a trustworthy source of information, so any of these would probably work well:
http://lifehacker.com/5237503/five-best-free-data-recovery-tools
Recuva, try using it, it's free and always works for me
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
Literally just tried that, it found nothing under the directory where the corrupted file is. Haven't tried the deep scan thing yet though.
Deep scan and come back here, if deep scan can't find anything, I'm afraid it's gone
@rice guru
Will do, he doesn't want to bother till he gets off then he'll do it overnight. Will update.
Good luck :)
@rice guru
