Motorola Droid reset
Go to solution Solved by 8uhbbhu8,
So I found the solution to this problem. Its actually a combination of 2 ways I found to reset the device that when combined work.
press and hold x and power on
once it shows the android with the white triangle and yellow ! press @
This is the combo that works for my device.... Not a single tutorial, video, or manual had this combo in it.
So I recently got my hands on a Motorola Droid. I think its running Android 2.2. The problem is its in Portuguese and locked. I dont have the username and password for it but i do seem to have access to all files via windows. (see pic 1) I've tried to factory reset it via motorola specifications but those don't seem to work. Is there anyway to edit the files directly to gain access or can i find the original files somewhere and just replace them?
Use this guide to fix text problems in your postGo here and here for all your power supply needs
New Build Currently Under Construction! See here!!!! ----->
Deathwatch:[CPU I7 4790K @ 4.5GHz][RAM TEAM VULCAN 16 GB 1600][MB ASRock Z97 Anniversary][GPU XFX Radeon RX 480 8GB][STORAGE 250GB SAMSUNG EVO SSD Samsung 2TB HDD 2TB WD External Drive][COOLER Cooler Master Hyper 212 Evo][PSU Cooler Master 650M][Case Thermaltake Core V31]
Cupid:[CPU Core 2 Duo E8600 3.33GHz][RAM 3 GB DDR2][750GB Samsung 2.5" HDD/HDD Seagate 80GB SATA/Samsung 80GB IDE/WD 325GB IDE][MB Acer M1641][CASE Antec][[PSU Altec 425 Watt][GPU Radeon HD 4890 1GB][TP-Link 54MBps Wireless Card]
Carlile: [CPU 2x Pentium 3 1.4GHz][MB ASUS TR-DLS][RAM 2x 512MB DDR ECC Registered][GPU Nvidia TNT2 Pro][PSU Enermax][HDD 1 IDE 160GB, 4 SCSI 70GB][RAID CARD Dell Perc 3]
Zeonnight [CPU AMD Athlon x2 4400][GPU Sapphire Radeon 4650 1GB][RAM 2GB DDR2]
Server [CPU 2x Xeon L5630][PSU Dell Poweredge 850w][HDD 1 SATA 160GB, 3 SAS 146GB][RAID CARD Dell Perc 6i]
Kero [CPU Pentium 1 133Mhz] [GPU Cirrus Logic LCD 1MB Graphics Controller] [Ram 48MB ][HDD 1.4GB Hitachi IDE]
Mining Rig: [CPU Athlon 64 X2 4400+][GPUS 9 RX 560s, 2 RX 570][HDD 160GB something][RAM 8GBs DDR3][PSUs 1 Thermaltake 700w, 2 Delta 900w 120v Server modded]
RAINBOWS!!!
 QUOTE ME SO I CAN SEE YOUR REPLYS!!!!
https://linustechtips.com/topic/605414-motorola-droid-reset/
I thought I might need that sort of thing but the problem im having is where in the file system are these settings stored? For the life of me I cant seem to find them! (im pretty fine with binary and HEX if thats how its going to read out when im editing it btw and i have some knowledge of the linux filesystem)
RAINBOWS!!!
https://linustechtips.com/topic/605414-motorola-droid-reset/#findComment-7847321
RAINBOWS!!!
https://linustechtips.com/topic/605414-motorola-droid-reset/#findComment-7848364
