Posts disappear after changing the title.
Go to solution Solved by LogicalDrm,
48 minutes ago, TeoIzAwezome said:
I did see one and it put around 9 posts on the reply box. Bug? When I was editing there was only my post, and when I was done there were two posts.
That sound like quote button just copied the one multiple times. Or that you had multiple other posts in multi-quote cache (or clipboard) and you replied accidently to those others too. If you are browsing with tabs, multiquote will combine all quotes you pick from different tabs/thrads.
Razer Blade 14, Windows 10 Home 64-bit, Chrome 50
I made a post in new builds section, and I realized that I'd written part of the title incorrectly, so I edited it. After that a bunch of posts disappeared and the only way I could see them was with the 'Quote all posts' button. Here's the topic: https://linustechtips.com/main/topic/604901-tubs-build-sub-600-dollar-workstation-pc/
Almost breaking sig rules 1.0
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
https://linustechtips.com/topic/604911-posts-disappear-after-changing-the-title/
Quote all posts button? There is multiquote, that lets you quote more than one post at once, but there isn't a button to quote all of them at once.
How many posts were there in the topic before you edited it?
HTTP/2 203
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
I am certain that there were no posts made in that thread other than the ones that are currently visible - there are several logs that have no trace of your phantom posts. What were the posts that appeared when you clicked this "quote all posts" button?
HTTP/2 203
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Oh, OK, thanks! That must be what happened.
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
