2 minutes ago, CJtheDJ said:
 A few months ago I ran all the cables into the back and stuffed the unused ones behind the storage for hdd, but now I want to make it look better. What can I do to make it look better?
Welcome to the Forums!
One thing I would do is to change the PSU and go for a fully modular unit to clear up the clutter and use lots of cable ties or clamps to hold everything down.
5 minutes ago, CJtheDJ said:
I've actually been looking for a new one but I don't know the difference between gold, bronze, platinum. All I know is that I should look for one that's 80+. Any recommendations?
Here I suggest to take a quick read over this it explain it very well, as for a PSU itself what components are you running in your system:
EVGA Supernova G2. That's the best.
CPU: Ryzen 2 2700@ 4.0Ghz    Mobo: Gigabyte X470 Gaming 7 Wifi    Cooler: EVGA CLC 240    GPU: GTX1080 FTW DT @ 2113Mhz   PSU: EVGA 750W P2
Case: Fractal Design Meshify C   Displays: 34" LG34UC79G, 24" Dell
